SB's & Dynamic 9.5 Converters #1341878
11/26/12 10:08 PM
11/26/12 10:08 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
My tranny builder is a Dynamic converter distributor and It appears that I may be in the market for one. My current TA 10" unit flashes to 3500 rpms and I love it. I am curious what you street guys/gals are using with the above 9.5 converter.
I am wanting to see if he will increase the flash up to 37/3800 for me, but I wanted to check to see what you members are currently using. My traction is good in warmer temps so I don't want to go much higher. But if I am going to pay the extra $ for a 9.5, I want a little more rpms for the money.
What flash rpms are you running on the street with this converter and a SB?
Re: SB's & Dynamic 9.5 Converters [Re: YO7_A66] #1341879
11/26/12 10:58 PM
11/26/12 10:58 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have a 9 1/2 inch Dynamic convertor behind my 408 SB and so far Iam very happy with it.
My car weights 3400 lbs with a 3.73 gear, my convertor flashs to 4800RPMs and I even put 3.23s if I drive it out of town.
I would like to try an 8 inch but Iam afraid driving up the mountains to get out of the valley with 3.23s the 8 inch convertor would not be happy.
Re: SB's & Dynamic 9.5 Converters [Re: Darryls-Demon] #1341880
11/26/12 11:28 PM
11/26/12 11:28 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Your question does not have a reliable answer because Dynamic custom builds most all of their converters to suit the application. One 9-1/2" could, and most likely is totally different than the next.
I run a Dynamic 9-1/2" behind my 451, and it flashes to about 4200. But again, it was custom built to my cars spec's. Call Dynamic and talk to Shaun, he'll get your car & motor's spec's and your goals and build to suit. I think they generally run around $650.
Re: SB's & Dynamic 9.5 Converters [Re: StealthWedge67] #1341881
11/27/12 07:58 AM
11/27/12 07:58 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have a used one from my scamp I only took out to put in a 8in.I was going to hold on but ight sell.
Re: SB's & Dynamic 9.5 Converters [Re: Scamp408] #1341882
11/27/12 09:05 AM
11/27/12 09:05 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
""Call Dynamic and talk to Shaun""
My trans guy is a business partner with Frank Lupo. The two of them will spec out my converter, but it sounds like the stall may be in the 35-3600 range.
""I was going to hold on but might sell.""
Thank you for the offer, but I will be given a warranty on this rebuild and I would assume that a used converter may void that warranty. If I find out that the converter is my only issue, then I may contact you.
I am still interested to see the flash ratings of the 9.5 users with their SB's on the street
Thank you all for the replies.
Re: SB's & Dynamic 9.5 Converters [Re: YO7_A66] #1341883
11/27/12 06:10 PM
11/27/12 06:10 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
No problem its a lupo unit.
Re: SB's & Dynamic 9.5 Converters [Re: Scamp408] #1341884
02/01/13 04:25 PM
02/01/13 04:25 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am getting closer! My tranny builder just quoted me a Dynamic 9.5" unit. He spoke with Sean at Dynamic and they decided on a 3800-4000rpm unit for my setup. I hope to get my tranny and the converter in the next couple of weeks.
Thanks again for all your replies.
Re: SB's & Dynamic 9.5 Converters [Re: YO7_A66] #1341885
02/01/13 08:52 PM
02/01/13 08:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son and I both use the Dynamic 9.5 converter. I told them I wanted mine to drive normal but flash about 4200 and it works perfect. Mine is a bigblock in a heavy B-body but as was said they will build one to your car. Ron
Re: SB's & Dynamic 9.5 Converters [Re: 383man] #1341886
02/01/13 09:27 PM
02/01/13 09:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I run a 400 HP 360 and my dynamic 9.5 flashes at 4,400 rpm. When leaving from a stop if your very light on the accelerator it feels like a normal 340 converter, but if you leave normal it has more slip, but its FUN!!!!
