Forced to use 72 Charger patch panels on a 73 fender? #1336090
11/16/12 11:54 AM
11/16/12 11:54 AM
USA
brando Offline OP
brando  Offline OP
USA
My 1973 front fenders are back from the sandblasters and I need to replace the lower rear portion of both fenders (the part between the wheel opening and the edge of the doors).
I can ony find these for 1971-72.
Does any one know if these are made for the 73-74?
Any ideas on where to look or will the 71-72 patch panels work in a pinch?
thanks
brando
Re: Forced to use 72 Charger patch panels on a 73 fender? [Re: brando] #1336091
11/17/12 09:52 AM
11/17/12 09:52 AM
KCMO
K
kcmopar Offline
kcmopar  Offline
K
KCMO
Got the same problem, found this on the web but don't know anything about the company or quality
http://www.vintagepartsclub.com/servlet/the-8198/Dodge-Charger-Quarter-Panel/Detail
Re: Forced to use 72 Charger patch panels on a 73 fender? [Re: kcmopar] #1336092
11/19/12 02:25 PM
11/19/12 02:25 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Check with Tabco. Otherwise I don't think anyone is repopping 73-74 metal.
Re: Forced to use 72 Charger patch panels on a 73 fender? [Re: Montclaire] #1336093
11/20/12 11:32 AM
11/20/12 11:32 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
guys, he is talking about the "dogleg" area of fender, not quarters.
Brando, I ( and some guys more ) already replied you on the rest of boards you posted, check it
Re: Forced to use 72 Charger patch panels on a 73 fender? [Re: NachoRT74] #1336094
12/18/12 04:12 PM
12/18/12 04:12 PM
USA
brando Offline OP
brando  Offline OP
USA
I did, thank you very much. I was able to make them work as you predicted!!!!
