Valve Body Inspection #1335123
11/14/12 08:41 AM
11/14/12 08:41 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am getting ready to pull my valve body for a general inspection due to some issues that I have been having this Fall. Besides any floating debris, is there anything that I should be looking for ahead of time while I am in there?
I plan on taking out all of the springs and pistons and checking the piston bores. I want to check the springs just to make sure that they are all in one piece. Are there any gaskets on the VB that I need to inspect?
Note: This is a 727 which has a newer VB with the part throttle kickdown option, a TF-2 kit that I installed, and different 1-2 & 2-3 shift springs that I installed.
Re: Valve Body Inspection [Re: YO7_A66] #1335124
11/14/12 09:13 AM
11/14/12 09:13 AM
scratchnfotraction Offline
no gaskets IIRC,but you might want to get the 1 1/4" manual shift selector seal along with the TPV shaft seal.
those will be ez to change with the VB down and on the bench.
couple washers and a bolt/nut pulls the seal into the case, and TPV seal is done on the VB at the work bench.
make/get a mumbly peg for your detent ball for when it goes back together. holds ball in place while you put rooster comb back on.
good luck
Re: Valve Body Inspection [Re: scratchnfotraction] #1335125
11/14/12 10:10 AM
11/14/12 10:10 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
no gaskets. just keep things in order and look for damaged bores and scuffed valves.
Re: Valve Body Inspection [Re: lewtot184] #1335126
11/14/12 10:30 AM
11/14/12 10:30 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thanks allot for both of the replies!!
""TPV seal is done on the VB at the work bench"'
Please tell me what the TPB seal is.
Re: Valve Body Inspection [Re: YO7_A66] #1335127
11/14/12 10:35 AM
11/14/12 10:35 AM
TPB???
TPV = throttle pressure valve
in your breakdown pic,the TPV shaft/rooster comb/seal/washer/e-clip
it is under the flat washer and e-clip on the TPV shaft in the rooster comb housing where the shift/tpv levers are on the outside of case.
Re: Valve Body Inspection [Re: scratchnfotraction] #1335128
11/14/12 12:10 PM
11/14/12 12:10 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
TPV = throttle pressure valve: Thanks
I replaced the selector seal the last time I had the tranny out and it still appears to have no leaks. But if I end up pulling the tranny this time, I will check that out closer to make sure it looks good.
Thanks again.
