Re: Buying a rebuilt engine that has never been run
[Re: BSB67]
#1334757
11/21/12 02:57 AM
11/21/12 02:57 AM
Posts: 755 Oregon
moparmedic
They are going to check everything including rechecking the ballancing that was done.
1968 Coronet 1968 Charger 1966 A100 Pickup 1967 Barracuda 1970 Challenger 1972 Challenger 1973 Barracuda 2021 Ram 2500
[Re: moparmedic]
#1334760
12/14/12 01:28 AM
12/14/12 01:28 AM
Posts: 755 Oregon
moparmedic
I finally heard back from the machine shop. All the machine work that was done is good. The bore, balance, hone, all that. They recommend decking the block and surfacing the heads and redoing the valve job. The pistons are good quality but the rings are low bid. The machinist said they used mismatched main and rod bearings as if they just used left over parts from other jobs. Basically this engine was a good start and could have been run as is. I got it for $800 so I think I got a good deal. Just have to tweek it a bit now.
[Re: moparmedic]
#1334762
12/14/12 10:20 AM
12/14/12 10:20 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yes you did...
[Re: Dean_Kuzluzski]
#1334764
12/14/12 09:40 PM
12/14/12 09:40 PM
Posts: 755 Oregon
moparmedic
Yeah, not sure about that either. The guys at the machine shop didn't mention that as a possibility but could be. Just showed me the ones they took out and there were 3 different brands and one that wasn't marked and was a different color than the rest. Kind of weird.
Should get it back next week and get my tranny from Passon Performance in a couple weeks and be close to driving my Challenger. Just in time for winter...
[Re: moparmedic]
#1334765
12/16/12 01:59 PM
12/16/12 01:59 PM
Posts: 3,344 Central TX
roe
Central TX
I'm glad it seems to all be working out for you
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
#1334766
12/16/12 02:46 PM
12/16/12 02:46 PM
Posts: 4,309 Prospect, PA
BSB67
Prospect, PA
I've heard of engine builders using bearing halves from different sets to tweak the final clearances.
Right, but not from different manufacturers.
[Re: moparmedic]
#1334767
12/16/12 02:53 PM
12/16/12 02:53 PM
BSB67
Prospect, PA
Did you get the compression distance or compression height of the pistons from the machine shop?, or piston manufacturer and part number?
[Re: BSB67]
#1334768
12/16/12 09:31 PM
12/16/12 09:31 PM
Posts: 755 Oregon
moparmedic
I didn't. I am just doing a street engine, not going to go really wild with it. Just cleaning up a few things that the machine shop recommended and put it together and run it.
