Streetfighter Aspen project
#1328029
10/28/12 10:02 PM
10/28/12 10:02 PM
Posts: 163 Speedway In.
IndyDave
Speedway In.
I've wanted to build a car with some heavy stock car themes to it for a long time. I raced short track cars(always Mopars)and more recently I've been doing SCCA Solo and Club Racing with a Neon Coupe. Well, earlier this year the Neon was sold to a Chrysler employee who's going to race it at Waterford Hills and I started on my quest to build my dream car. The car: 1979 Dodge Aspen R/T. Originally a slant six car, right now it has a mildly built early 80's 318, a built 727, and a 8&3/4 with 4:10 gears. Found it on Craigslist in Nashville Tn. It has a fairly clean body, never been wrecked and only minor rust issues. The interior is typically cooked as wit many southern cars. That doesn't matter much as most of the interior will be removed and / or replaced. The PO mods were mostly done fairly well but there are some real goober mods also. The exhaust is especially bad yet funny at the same time. Again, doesn't matter because it's all going to be replaced. The wiring has all the typical hacks and crappy repairs of a home brewed backwoods hotrod. Again, all old going away and replaced with new. The idea: I'm building this car so I can autocross it, do track days, drive it on the street, basicly build a Pro-Touring streetfighter. The car will have a lot of styling cues from short track stock cars. Here's some of the cars that are my inspiration: Some details: The first thing to do is strip the car and get started on the fabricating. The major fabrication will be installing a rollcage and replacing the entire front stub with a Howe Racing Products fabricated road race front clip. This will allow me to go coil over, rack and pinion steering, and have endless adjustiblity for the fraction of the cost of what little else is available for an F-body. The rear suspension will be leaf spring for now but I'm considering truck arms. I'm going to work with the 318 for now as it's recently rebuilt and seems to run well. The big thing is to make it breath better and twist quicker. I'm also going retain the TF, I was impressed with how Mitch Lelito's Challenger drove with a TF on an autocross course. I will be looking to swap out the 4:10's though.
Dave Dusterberg 1979 Aspen R/T (soon to be #19 CAM/T) 2002 Ram 1500 SLT 2005 Magnum R/T 2005 Mustang GT SCCA CAM/C #19
Re: Streetfighter Aspen project
[Re: hemirdrnnr]
#1328032
11/21/12 05:00 PM
11/21/12 05:00 PM
Posts: 2,469 NE Ohio
mopar383
NE Ohio
Good Luck with it! I had a 77 RT In my younger days and loved it
81 Dodge Ram My dad bought brand new... my 17 year old sons project Jeep Wrangler Unlimited .....my wife's baby Durango....my DD Caravan...an awesome parts hauler 72 Dart
[Re: IndyDave]
#1328035
01/05/13 11:20 PM
01/05/13 11:20 PM
IndyDave
Speedway In.
Since buying the Aspen, I've not had a lot of time to pay attention to it. We bought a house and moved, remodeled the garage at the new house so I can comfortably work out of it, and a bunch of little things around the new house. In the meantime I did a few small things such as locating some needed Aspen specific parts like good taillights, some quarter window louvers, a grille, etc. Most of the time I spent on the car was investigating what to do about the car's front suspension. The factory transverse torsion bar front suspension isn't some of Chrysler's best engineering and is nothing but one compromise after another. I looked at a bunch of options and decided the best course of action was to cut the entire front off of the car and replace everything forward the firewall. My intention was to use a road race front frame from Howe Racing Products that is used on the TA2 Trans Am series cars they offer. Friday I was pulling everything together to place the order to Howe for the front frame, control arms, spindles, and hubs but their website was having issues and I was having troubles pulling together the P/Ns and prices I needed. While i was waiting for a page to load, I popped open another tab and started cruising E-Bay's race cars for sale when I stumbled upon this: What it is is a Laughlin short track chassis that was run as a NASCAR North Series car (NASCAR North is a ladder series that uses basicly the Nationwide Series Rules with less expensive bodies and more restrictive engine rules). It's a complete roller so it has suspension, brakes, rear end, and steering. The rear end is a quick change. The track width is just a half inch wider than the Aspen's stock track width and has a 105" wheelbase (The Aspen is 108"). All this for an opening bid just $200 more than I was getting ready to spend with Howe and it was a no reserve auction. So I bid and at 3pm today I won that auction so the Aspen will be getting a complete Laughlin chassis!
[Re: IndyDave]
#1328039
02/03/13 08:33 PM
02/03/13 08:33 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
NOW you're cooking!!!! Pic of one of my projects a few years ago..
If you like drag racing, support your local track.
[Re: IndyDave]
#1328042
03/08/13 11:57 PM
03/08/13 11:57 PM
IndyDave
Speedway In.
A quick update:
I've been busy with SCCA stuff, was elected President of the Board of Directors of the Indianapolis Region SCCA so I've been getting up to speed with that position. I was able to get a little garage time so i got the trusty tape measure out and went to work. The chassis width is perfect! The chassis' width fits inside the rockers of the Aspen. Using the main hoop on the chassis and the b pillar on the body as a common reference point, I made all my length measurements. I was hoping to find that I would be able to fudge the wheel openings a little to make up for the difference in the wheelbase between the Aspen and the chassis (The Aspen is 108.7" and the chassis is 105"). Unfortunately that won't be the case. From the b pillar forward, everything works out perfectly, all the difference in length happens from the b pillar back. So what I'm going to have to do is lengthen the chassis behind the main hoop 3 3/4". That means moving the truck arm mount rearward as well as the entire rear clip. That will also mean that I will have re-do all the bars from the main hoop back. No biggie really. Now that the weather is getting better I'll be able to spend more time in the garage. The only stumbling block right now is I have to get our Mustang GT ready for the upcoming autocross season.
