Lights dim/flicker at idle
#1323489
10/20/12 06:28 PM
10/20/12 06:28 PM
Posts: 15,822 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
The lights (headlights, dash lights) dim greatly at idle, and then brighten back with any increase in idle on my mostly stock '89 Diplomat police car. There is a bit of flickering too. When I first got the car I immediately had the alternator rebuilt because car had sat so long and I didn't want to chance it. I also have replaced the voltage regulator. I really don't know if it was doing this before I replaced these things because I didn't drive it at night prior. The battery cables look fine, and I cleaned the ground cable to the block real well. Seems to be charging ok, but continues to dim and flicker. It is the 100 amp police alternator, and it does this even when the only thing turned on is the headlights. My others don't do this. It is a very noticable dimming/brightening/flickering. What to I try next? Thanks.
Facts are stubborn things.
Re: Lights dim at idle
[Re: larrymopar360]
#1323490
10/20/12 06:47 PM
10/20/12 06:47 PM
RapidRobert
I'd clean the bulkhead halves thoroughly along with the rest of the charging circuit and grounds. That solved my dim at idle/brightening when speeded up issue
[Re: scratchnfotraction]
#1323492
11/17/12 09:26 PM
11/17/12 09:26 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Still have this problem. I cleaned up all the grounds I can see. Ran another ground wire from VR too (also has factory ground straps all over the place including from VR to hood). The fusable link along the drivers side underhood looks ok...if that means anything. The problem is definetly more than just a low idle. The clock on the radio is flashing dimmer and brighter with the turn signals too. Stopped by a good auto electric shop in town. He suggested it could be the ignition switch. Anybody have any thoughts on that? He said he would spend a little time checking it out one day, but it is at $85 an hour. Wondering, could it be the connections at the starter, or is that not likely? Thanks.
[Re: RapidRobert]
#1323494
11/17/12 10:10 PM
11/17/12 10:10 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I could give that a shot (the other cars are fine). I did swap one of the other Voltage Regulators but same issue. I was wondering if the battery could actually cause this issue too...was thinking about swapping that out too. Thanks.
[Re: larrymopar360]
#1323495
11/17/12 11:14 PM
11/17/12 11:14 PM
RapidRobert
To me I think the flickering means that there's a variation on the demand side (accessories/devices being fed) & I dont think that's the case or a variation on the supply side (the alt). Yes if you have another 100 amper I would swap it & see what comes of that
[Re: RapidRobert]
#1323496
11/18/12 12:22 AM
11/18/12 12:22 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I am going to try swapping the alternators asap (hopefully get a chance in the next day or two). It's driving me nuts!
[Re: 1_WILD_RT]
#1323499
11/18/12 11:14 AM
11/18/12 11:14 AM
Posts: 4,705 Florida
BDW
Quit wasting time & just add relays for high & low beams..
What he said, x2
[Re: ahy]
#1323500
11/18/12 02:38 PM
11/18/12 02:38 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I really appreciate the input here because I am stuck. Ahy: yes, stock pulleys. I have two other ex police cars with the 100 amp alts and no dimming. It does have the same heavy gauge wire on the alternator like the other cars and I have cleaned it up real well too. The flickering now has me much more concerned than the dimming. The dash lights, clock on radio, etc. flicker and especially when I have a turn signal on. If I can at least try a few things first then maybe take it to the $85/hr guy to check it out. Thanks!
[Re: Supercuda]
#1323504
11/18/12 08:22 PM
11/18/12 08:22 PM
DaytonaTurbo
Manitoba, Canada
Replace/run a new heavy gauge wire from the alternator output straight to the battery +. I don't know how your diplomat is wired as the older mopars ran this wire through the firewall to the ammeter, then to the battery. Sometimes the old wires can get all corroded inside and lose conductivity even though they visually look fine.
Not applicable to the Diplomat, it uses a shunt resistor to drive the ammeter. So the current never passes thru the bulkhead connection. Sounds like the alternator is flaky to me. Possibly a diode issue internal to it.
Yes but there's nothing to say his stock 30 year old piece of wire going from the alternator to the battery isn't pooched. New connector at the alternator end? New battery terminals? I agree that swapping the alternator is something he should try before mucking around with the wiring.
[Re: larrymopar360]
#1323506
11/21/12 06:21 PM
11/21/12 06:21 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Darn it, not the alternator. I swapped them last night and same flickering of dash lights, radio clock, etc.
Don't know why I didn't think of trying this before, but today I turned the key on (not started) and with just the radio on, I turned on a turn signal. The clock on radio flashed with signal bigtime. Does this eliminate anything since the engine wasn't running. Could it be something with the battery? They are a bit of a pain to swap with the Thermoguards, but will gladly try it if it isn't a complete waste of time. Thank you.
[Re: larrymopar360]
#1323508
11/21/12 08:08 PM
11/21/12 08:08 PM
Posts: 1,357 central Florida
VL21
central Florida
First, I am an electrical idiot.
Just for something to try, and eliminate the switch, try switch off. Lights on. Then pull on the 4 way flashers. Bypasses the ign switch. This will probably still pulsate the clock. I think there is a bad ground somewhere, you may have a bulb filament shorting across or something, or bad firewall connection? The whole dash panel cluster surround is made of plastic on your car, make sure it is functionally grounded. While the lights are flashing, walk around, looking for something that is on or pulsing that shouldn't be. Maybe something is being back fed. Dome lights, trailer wiring? If this is a Fla car and has an aftermarket hitch, it is almost guaranteed that scotch locks or that ilk was used to wire in the trailer plug. OK,ok, I've done it myself too.
It takes gasoline to interest me.
