84 D350 - brake light fuse - blows again. #1321951
10/17/12 07:01 PM
10/17/12 07:01 PM
Tennessee
WyleECoyote Offline OP
Tennessee
So I've been driving my truck for 10 years now without any problems. A month ago, a guy pulls up beside me to tell me I have no brake lights. I check the fuse and its blown. I replace the fuse and its good to go. I check the brake lights several days in a row with no problems. Yesterday my neighbor follows me to my driveway to tell me I have no brake lights.
Why would I start blowing fuses all of a sudden?
Could a socket be bad? If it was a short - wouldn't it blow instantly when I apply the brakes?
Thanks in advance for your ideas and shared experiences.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 84 D350 - brake light fuse - blows again. [Re: WyleECoyote] #1321952
10/17/12 07:32 PM
10/17/12 07:32 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You have a short somewhere it sounds like to me. If you have trailer wiring or have pulled a trailer lately with a short it could also be your problem. I would inspect the wiring harness under the truck first for chaffing or a broken loose wire. Again, if there is trailer wiring that is tapped into the main harness I would look there first. If you have an electric trailer brake controller, check it out also.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 84 D350 - brake light fuse - blows again. [Re: 71yelladustr] #1321953
10/17/12 07:39 PM
10/17/12 07:39 PM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
Re: 84 D350 - brake light fuse - blows again. [Re: '84 D150 Shorty] #1321954
10/17/12 07:51 PM
10/17/12 07:51 PM
Tennessee
Tennessee
Why yes I did tow my trailer recently - and I have not done so in many years. I reckon I'll be climbing under there for some inspectin'.
How could hooking up the trailer "start" a problem? The short was created through the wiring to the trailer - that normally wouldn't happen without a "draw" on those wires with no trailer?
Wile E. Coyote
Re: 84 D350 - brake light fuse - blows again. [Re: WyleECoyote] #1321955
10/17/12 08:35 PM
10/17/12 08:35 PM
As said good visual in that circuit from head to toe for the loose connection that's makeing an occaisional dead short to ground that's blowing the fuse. The socket(s) at the rear might be a logical place to start. Holler what it ends up being
