Re: PPG clear coats?
[Re: reflections7]
#131801
10/11/08 07:21 PM
10/11/08 07:21 PM
Posts: 1,271 eastern long island,NY
JeepJimmy
i see you guys like the transtar but i cant get it locally and im thinking id rather stick with PPG on PPG and use the 2021 im leaning towards for the higher solids.. and for some reason id be using less and getting more if that makes sense! maybe im crazy i dunno heh
70 duster 360magnum, 1975 jeep j-10.
[Re: JeepJimmy]
#131802
10/11/08 07:39 PM
10/11/08 07:39 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
I am not a pro, but I used 2021 on my engine compartment, and I am quite impress for the first time I have sprayed base/clear...
I think it is good product, it flows well it is designed to set with just an air dry; the other thing I like about it is it turns K36 into a sealer - so you do not have to buy as many products...
it flows so well when I painted my engine compartment I got stuck in a corner and stopped moving the gun but left the trigger down for a second too long - it cam out and it was going to be run city, but it just flowed out w/ no runs - you could just see it flatten out...
One not is have good ventilation when spraying, even with my Devilivus CFG-670 plus gun it left a large haze in the garrage, I had to spray a side, wait for the overspray to clear out, then do the next panel...
[Re: 6T6Cuda]
#131803
10/11/08 08:56 PM
10/11/08 08:56 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
I've done a couple of cars and we used the Omni base (because of cost) w/a Global 894 Clear. Was this a good way to go? If I recall the clear was real spendy. thx matt
[img] [/img]
[Re: JeepJimmy]
#131804
10/12/08 11:47 AM
10/12/08 11:47 AM
Just curious as to why you would want to use Base/clear for Panther pink ? To me it would make more sense to use a single stage like Delstar or Centari or one of the urethanes.Solid colors don't really need clear to look shiny and there is less chance of getting dirt in the finish with a single stage paint.
[Re: JeepJimmy]
#131807
10/13/08 02:42 PM
10/13/08 02:42 PM
Posts: 5,651 South Dakota
hotairballoonpilot
South Dakota
transtar for me! To bad you can't get it! It is the $hit! I just shot some shopline this sunday just to try it. Nope not for me! Very watered down! Had 2 runs where I don't get runs with transtar. I didn't change my spray habits on a side not should have but oh well it is just the wife's minivan! If you can't get transtar go with 2021. I sprayed it air dry in abooth and had no problems when I do it! Good luck
Contact Me about AMD Prices
