Re: 55 dodge truck on a 2005 dakota chassis
[Re: Dabee]
#1313951
10/01/12 08:28 PM
10/01/12 08:28 PM
moparpollack
Lil Herman
Lil Herman
85086
I'm using a 95 Dakota for my 39 Plymouth project. So far the project has been simple and pretty easy. If you look on the HAMB there are a few projects using the Dakota chassis.
The rack being up front makes locating the engine easy. The only change I have to make on the chassis is the fuel system because I'm using a carb instead of fuel injection. Cutting the bed sides off made the bed floor easy since it was in place. The bed floor will be shallower than stock but I'm fine with that. The bed floor kicks up so trying to make a deep bed will be a challenge.
Setting the ride height and making the cab mounts was a little challenging since I didn't have a lift to hold things in place. Changing the bolt pattern is a matter of changing the rotors. The truck us wide enough that a b body rear end is two inches narrower than the stock Dakota rear end.
[Re: poorboy]
#1313953
10/02/12 09:37 AM
10/02/12 09:37 AM
moparpollack
Lil Herman
Lil Herman
85086
The older caps fit the spare steelie wheels so it's. Cheap fix for a minute or until you decide on wheels.
[Re: Dabee]
#1313955
11/08/12 03:46 PM
11/08/12 03:46 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I married an 88 Dak frame with a 57 truck frame. I joined them with a half-lap joint at the rear of the cab. I didn't like the idea of all the stress being at the front of the cab. After you join the frame halfs, it is just a matter of cutting off the truck cab mounts and rewelding them to the Dak frame. You can set your cab ride height then. If you need some pics, I could send them from my home computer.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: Dabee]
#1313957
11/09/12 03:02 PM
11/09/12 03:02 PM
rattler
Crofton, Ky.
I'll try to send you some pics this weekend if I don't forget.
[Re: Dabee]
#1313961
11/11/12 10:42 AM
11/11/12 10:42 AM
rattler
Crofton, Ky.
That looks good. One of the reasons I didn' do mine like that is that 57 trucks narrow quite a bit just behind the motor center, making pipes and sush a tight fit.
[Re: rattler]
#1313962
12/29/12 02:35 AM
12/29/12 02:35 AM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
A friend of mine dropped his field-find '52 "Binder" onto a late 1990's LWB Dakota. He said the length of the frame is much easier to modify than the WIDTH, and the the width of the Dakota chassis fit perfectly once he shortened the frame. He even kept the Dakota floor, firewall, dash, ECU, gas tank, etc.
It was a 6-lug truck, so he ordered black steel wheels (cheap) and used some old wheel covers he had lying around.
Most important: pay attention to the track width comparisons between your truck and whichever Dakota you use.
[Re: 300by500]
#1313963
12/29/12 11:18 AM
12/29/12 11:18 AM
rattler
Crofton, Ky.
Agreed on the track width. That is the biggest problem when people use a full size truck frame under an old truck. The track is just too wide and the don't look right.
[Re: Dabee]
#1313964
12/31/12 01:03 AM
12/31/12 01:03 AM
Posts: 10,537 Freeport IL USA
poorboy
Freeport IL USA
Thanks that looks close to how I知 thinking I need to do mine. Having never done this before I知 looking for confirmation I知 not about to do something stupid. I have built full tube chassis race cars before but this is my first street rod project and attempt to mate two chassis.
If you have built tube chassis race cars, this frame splice and swap will be a walk in the park.
I have a 48 Plymouth business coupe sitting on a 90 Dakota frame. I used the frame, floor pans, firewall, box floor and the full Dakota drive train. My biggest issue was the 48 body was rotted out bad. its not pretty yet, but I put almost 4,000 miles on it last summer. Would have put a lot more on it if gas wasn't so expensive and I was so broke. Gene
[Re: MOPARS#1]
#1313966
01/02/13 01:59 PM
01/02/13 01:59 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
if im not mistaken,the later dakotas starting in ?? are strut front end,not using an upper A arm,,i would think that would make it super involoved to use a strt front end frame,,
65 dodge your splice looks great,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
