Re: good drill size to prime a big block
[Re: mickm]
#1311105
09/26/12 05:59 PM
09/26/12 05:59 PM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Can't imagine why a 3/8 wouldn't do the job unless it is just wore out. Good excuse to buy a good cordless tho . Something 18v or better. Kevin
[Re: Dodgem]
#1311107
09/26/12 06:13 PM
09/26/12 06:13 PM
Challenger 1
Cincinnati, Ohio
I used to do it with a 3/8 had them smoking a few times lately been using a 1/2 drill it's just right! :-)
Yes you need a 1/2" drill imo. Milwaukee to answer your question on what brand imo. If you own it you will use for something other than priming motors. Got to have a 1/2" drill as you go through life.
[Re: bobs66440]
#1311110
09/26/12 08:03 PM
09/26/12 08:03 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Milwaukee, 1/2 variable speed gear reduced..(like a Mopar starter). It will prime it, for a long time... Dont forget to rotate the engine while priming to get both rockers/ heads lubed... And ...hold on tight ! and run in reverse..
[Re: sthemi]
#1311111
09/26/12 08:35 PM
09/26/12 08:35 PM
Challenger 1
Cincinnati, Ohio
Just happen to have both of my Milwaukee 1/2" drills in the same place, don't happen often. Both drills easliy over 10 years old and the big one has honed many engines with a real sunnen hone which takes some big azz arms and a strong back. Then the drill get's so hot you can't can't hold it no more with heavy leather gloves on, many times and it still works like new.
[Re: Exit1965]
#1311113
09/26/12 11:38 PM
09/26/12 11:38 PM
RapidRobert
With it dot to dot (6/12 o'clock) #6 is on compression/with the timing marks at TDC I believe the pass head oils then back up 3/4 turn (270 deg) till #8 is firing (rotor under #8 cap terminal) & see if the dr head is oiling. Easier on you (& the drill) & wipes less goop off of the cam lobes
[Re: AndyF]
#1311115
09/26/12 11:51 PM
09/26/12 11:51 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
No need for a drill, just use a speed wrench and turn it by hand. You only need to spin the wrench a few times to build up the oil pressure.
God did not invent power tools so we could use manual tools! As tim says Ya need more power!
[Re: Cab_Burge]
#1311117
09/27/12 08:06 AM
09/27/12 08:06 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I use an old and I mean old Craftsman 1/2 that I got at a yard sale for 3 bucks probally 20 years ago.I tried 3/8s but they never had enough umph when the pressue built.I like to see a lot of oil flowing when I prime.Rocky
Chrysler Firepower
[Re: AndyF]
#1311118
09/27/12 08:58 AM
09/27/12 08:58 AM
Challenger 1
Cincinnati, Ohio
Tim Taylor the tool man said we are supposed to use power tools, arrrggh.
I do agree it can be done by hand but that would be more like work!
[Re: therocks]
#1311119
09/27/12 09:23 AM
09/27/12 09:23 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
I have one of these big old 1/2 Craftsman drills , it only spins at 600 rpm.
[Re: AndyF]
#1311120
09/27/12 12:16 PM
09/27/12 12:16 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
It takes less than a minute to prime with a speed handle.
[Re: 446acuda]
#1311121
09/27/12 01:07 PM
09/27/12 01:07 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
My dad had a couple of the aformentioned big 1/2 inch craftsman drills. It primed quite a few motors years back before finally passing.
I smoked my Dewalt 1/2 after priming 2 440s. Still works fine, but the batteries are toast.
Smoked my 1/2 Skil the other day on a sbc motor. The Skil doesnt have much umphh...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: 446acuda]
#1311122
09/27/12 02:59 PM
09/27/12 02:59 PM
Posts: 4,179 California
mickm
California
ok, priming the pump i can understand. but i want to prime the engine. if it takes a good 1/2" drill to do this, then how can you possibly prime the engine by hand?
well, reasonably anyway. i'm sure it can be done, but it's probably better than a weeks workout at the gym!
[Re: 446acuda]
#1311125
09/27/12 05:15 PM
09/27/12 05:15 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Not sure either why 1/2" is needed. I've done it many times with a plain 'ole $60 3/8" Dewalt. Yeah, it gets warm, but by that time the job is done anyway.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: 383man]
#1311126
09/27/12 06:14 PM
09/27/12 06:14 PM
mickm
California
wow, this has been an eye opener! my 3/8" drill is old, and while i may give it a try, i'm going to bail as soon as it shows any signs of not liking it. it's a perfect little drill for 90% of what i need to do, so i don't need to ruin it or send it on it's way to ruination just to prime one engine. i'm also going to give it a shot by hand and see how that goes. from the sounds of it, i won't need the 1/2", although as posted earlier, hard to get through life without a good 1/2"
[Re: mickm]
#1311127
09/27/12 07:38 PM
09/27/12 07:38 PM
RapidRobert
If you can would you note (& post) the 2 points where it oils
[Re: RapidRobert]
#1311128
09/28/12 12:32 AM
09/28/12 12:32 AM
mickm
California
i assume you mean where it oils the rocker shafts? my #4 cam journal is grooved, so it should provide constant oil, even if a small amount.
[Re: mickm]
#1311129
09/28/12 01:03 AM
09/28/12 01:03 AM
RapidRobert
In that case yes you'll have full time oiling
[Re: RapidRobert]
#1311130
09/28/12 02:55 AM
09/28/12 02:55 AM
mickm
California
may need to start another thread, but here goes.
only had 3 qts of oil, but wanted to check out priming it by hand or with the 3/8". tried for a while by hand, (yes, counter-clockwise), and didn't get anything. tried the 3/8", and it grabbed pretty quickly, but then let off and was turning fairly easily. i could hear what sounded like air being sucked up into the pickup. even though the filter was not primed, i still thought that 3 qts would be enough.
so i put a 4th qt in, and that seemed to do it. now the drill is turning pretty slow, it's an old drill, and not much torque there. the engine was at TDC on the #1 cylinder, and i started to get a good amount of oil at the passenger side exhaust rockers, but that's it. i moved the crank around a bit to where it thought it might line up the hole for the driver side, but didn't get anything there at all.
so what now? try with a stronger drill? i would definitely like to see oil on the other side before i button this thing up. i know the passages in the block and head are clear, i spent a lot of time with brushes cleaning everything out when i did the block.
is it just because i don't have enough power on the drill? i was thinking that even though the cam is grooved, if the hole was lined up for the pass side, that might have filled that side up, path of least resistance. now that it's full, it doesn't take much to push what's there out.
anyway, any suggestions on making sure i have oil on the other side?
[Re: RapidRobert]
#1311134
09/28/12 01:29 PM
09/28/12 01:29 PM
mickm
California
Keep it all in the same thread! Dont button it up till you get the other side squared away. with full time oiling there's no reason both sides shouldn't be recieving oil. I'd continue to prime it & if need be take off the rocker assy & see if the pedestal has psi (as you know cover it with something). I'm assuming the cam is gooped and the intake is on so you wouldn't want to do alot of hand turning which you shouln't need anyhow. I'd continue to drill prime it & maybe toss in another qt (can drain the qt before firing to get the level right) & if the drill has enough oats to prime one side then it's enough for the other side.
it's a roller cam, so no issue there.
i'll do all that this weekend and post back. thanks!
