Re: quick Transgo TF2 question
[Re: John_Kunkel]
#1306291
09/19/12 08:25 AM
09/19/12 08:25 AM
Posts: 582 PA
BTTG
PA
John, Sorry I think I confused you. My hand written notes on the instruction sheet probably didn't help. I will drill out the rear servo hole larger. This is near where the accumulator spring recess is on the transfer plate.
The check ball in question is not under that rear servo feed hole, but is towards the front of the car. see red arrow in the photo attached to this reply...on the right hand photo of the transfer plate at the top center. I believe that this ball should stay for street/strip since it was present before modification? From Munroe book looks like it feeds the rear clutch apply port,... possibly?
[Re: BTTG]
#1306292
09/19/12 08:38 PM
09/19/12 08:38 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The check ball at the red arrow is the rear clutch feed; although most sources say to toss this ball I think it serves a useful purpose. It protects the rear clutch Belleville.
[Re: John_Kunkel]
#1306294
09/12/13 09:31 PM
09/12/13 09:31 PM
Posts: 3,009 Sac, CA
mopowers
Sac, CA
my separator plate has only 1 smaller hole there now and no checkball under that location in the transfer plate
Drill the hole to 3/16" or larger but DO NOT install a ball...doing so will shut off the rear servo.
The reference to a ball in that location is only if the plate has two holes and an existing ball.
I'm in the process of installing one of these TF2 kits too. I was confused about this step as well. My valve body has one hole at the "R" location and no ball. I just drilled it out to 3/16". The way I read these instructions was to install the ball as well. Is this wrong???
[Re: mopowers]
#1306295
09/13/13 01:40 PM
09/13/13 01:40 PM
John_Kunkel
Rio Linda, CA
If the "R" location had a single hole and no ball, installing a ball is wrong. The ball is only for the plates that original had two holes and a ball in that location.
