1995 360 Mechanical Fuel Pump Suggestion #1305158
09/16/12 10:17 PM
09/16/12 10:17 PM
McHenry, Illinois
RAUPLEMINZE454 Offline OP
McHenry, Illinois
It will be in a street/strip car and I need to adapt it to a 6 AN. Mild 95 360 roller engine in the car now. I was leaning towards this....
http://www.summitracing.com/parts/CRT-M6270/
Any feedback?
Suggestions?
Thanks in advance,
Brian
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305159
09/17/12 12:12 AM
09/17/12 12:12 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I ran one on my 70' 340 Duster 8.20's in the 1/8 mile with no problems
Drove it to work everyday
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: BulletBob] #1305160
09/25/12 03:34 PM
09/25/12 03:34 PM
McHenry, Illinois
McHenry, Illinois
Did you run any type of pressure regulator? Anybody else using one?
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305161
09/25/12 04:16 PM
09/25/12 04:16 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
That pump may need a regulator. If you do not want to use a regulator, try the Carter Super Mechanical M6902. I just put one on my 340 a few weeks ago and it puts out 7psi and no need for a regulator with my carb.
http://chucker54.stores.yahoo.net/cam6sumefupu.html
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: YO7_A66] #1305162
09/25/12 05:00 PM
09/25/12 05:00 PM
dogdays Offline
dogdays  Offline
Forget mechanical, put a Carter street Pump, P4070, back near the fuel tank. Run it off a switched power source. No regulator needed.
R.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305163
09/25/12 05:07 PM
09/25/12 05:07 PM
scratchnfotraction Offline
the 95 360 is a magnum engine correct?
are you going to run a LA pre-magnum t-cover to mount a mech FP?
remember to order a long nose roller cam to fit the FP eccentric on the cam.
or an adaptor for a short nose cam from Hughes.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: scratchnfotraction] #1305164
09/25/12 06:13 PM
09/25/12 06:13 PM
McHenry, Illinois
McHenry, Illinois
Hey Scratch what's up?
I'm not sure what all of that means?
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305165
09/25/12 09:59 PM
09/25/12 09:59 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
What Mike is talking about is this:
Stock Mag cam doesn't have the extension for the fuel pump eccentric
Hughes sells a kit to put that eccentric on
You can get aftermarket cams with or without the extension made on
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305166
09/25/12 10:02 PM
09/25/12 10:02 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I used a return style regulator
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: BulletBob] #1305167
09/26/12 02:27 PM
09/26/12 02:27 PM
dogdays Offline
dogdays  Offline
Carter Street Pump doesn't need a regulator or a return line. Its output is something like 4-5 psi.
R.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: dogdays] #1305168
09/26/12 05:07 PM
09/26/12 05:07 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The Carter pump that I used was the same pump used in NASCAR & was one the was used by the King himself on one of his Magnums in the late 70's
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: BulletBob] #1305169
10/01/12 08:33 PM
10/01/12 08:33 PM
McHenry, Illinois
McHenry, Illinois
This is all I know about the engine:
360 Plate Honed-Decked Square
.040 over KB #107 Flat top pistons
File Fit Rings 5/64's
Stock Rods Resized w/ARP Bolts
Stock 360 Crank 010/010
Clevite Bearings
New Standard Volume Pump
Stock Pan w/New Pickup
Comp Double Roller Timing Set
Mopar Chain Tensioner
Mopar Performance Hydraulic Roller Cam
230-234 @ 050 464 478 Lift 107 LSA
Mopar Stamped Rockers 1.5 Ratio
New SBI Lifters
"587" 360 Heads 1.88-1.60 Valve
Crane Springs, B Ported and Gasket Matched
74 cc
Stock 360 balance will need B&M Flexplate for early 360 or 360 weighted converter or Mopar 360 flywheel for early 360 like a 70's model
NOT magnum balance
New Mopar Distributor
New Hi Flow Water Pump
Edelbrock Airgap Intake
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305170
10/05/12 12:02 AM
10/05/12 12:02 AM
McHenry, Illinois
McHenry, Illinois
Any idea how to find out if this cam is set up for a mechanical fuel pump?
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305171
10/06/12 07:45 AM
10/06/12 07:45 AM
I have a stock short nose roller cam on the shelf,i will measure the nose and you can see if yours is longer or same.
I orderd my lunati voodoo roller cam with the long nose when I went roller cam.
if it is short you can get the adaptor from hughes to run the ecentric for mech pump.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305172
10/06/12 09:27 AM
10/06/12 09:27 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
im wondering this also,without pulling intake.can you look into the fuel pump block off plate to see?
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: mcmopars] #1305173
10/07/12 10:17 PM
10/07/12 10:17 PM
McHenry, Illinois
McHenry, Illinois
The engine builder got back to me and said he usually puts an eccentric on for mechanical pump use. Is there a way to pull the fuel pump plate off and check? If so what am I looking for?
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: RAUPLEMINZE454] #1305174
10/07/12 10:52 PM
10/07/12 10:52 PM
on a short nose cam it will have the t-gear and a different style washer/bolt.
if it has the ecentric,you should see it in front of the t-gear looking into the fp hole.
IIRC a magnum has a thinner t-cover and this is why a fp ecentric will not fit behind the mag cover.
but by using a pre-magnum t-cover and the hughes fp adaptor you can run an ecentric on the short nose cam.
if the roller cam pre-mag engine had a carb it had a long nose roller cam for fp ecentric. if it was TBI it had the short nose roller cam with no ecentric but still had room in the t-cover for it. pre-mag TBI t-cover got a fp block off plate.
the pre-mag roller cams,short or long, will have the bearing journal drill for oil the rockers thru the heads.
a magnum roller cam will not. and it can not be used in a pre-mag LA engine block.
here is a pic of the short roller cam nose with a tape mearsure for referance.
make note of the flat t-gear washer and bolt. this is different from the ecentric and its own washer/bolt.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: scratchnfotraction] #1305175
10/07/12 10:58 PM
10/07/12 10:58 PM
if you look in the first pic with the bolt washer turned in. there is no room for the thickness of the ecentric to fit.
the key way is flush in the t-gear with the flat washer.
on a long nose the keyway is sticking out to go in the keyway of the ecentric. with a bell type washer/bolt.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: scratchnfotraction] #1305176
10/07/12 11:12 PM
10/07/12 11:12 PM
do you have a part# for that cam?
I have a mopar catalog I can look the specs up.
yes you can see the ecentric in place thru the FP hole.
4 things I would want to know.
1)is it a long or short nose roller cam?
2) is it drilled to oil thru head to the shaft rockers?
3) are the roller lifters oil thru style with hollow PRs?
(they can use solid PRs also but good to know what you have.)
*** 4) did they drill the 95 block to oil thru the heads to the shaft mount rockers??
magnum blocks are not drilled for LA style oiling when running pre-mag heads.
Re: 1995 360 Mechanical Fuel Pump Suggestion [Re: scratchnfotraction] #1305177
10/08/12 01:52 AM
10/08/12 01:52 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Mike you covered all the bases
