727 Debug Questions
#1305123
09/16/12 10:02 PM
09/16/12 10:02 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I had a strange shifting issue tonight when I tried to go for a drive. I have some very vague descriptions that I need your guesses on so that I know what to look for when I pull the pan. A) When I startup the car in P then I move the selector to N, the rpms drop like there is a drag when the tranny is cold in N. Then as soon as I move the selector back to P, then the rpms go back up. Once the tranny is warmed up in N for a few seconds, then the rpms do not drop. B) After I had the strange shifting issue tonight, I parked the car in the garage and shut it off. Then I put the car in N and started to push it forward then it felt like I ran over something while pushing the car forward. I put the car in P then looked under the car to see if I could see anything that may have been in front of one of the tires and there was nothing under the car. Then I put the car in N and pushed it backwards a few inches, then forward the rest of the way in the garage. It was strange that when I was pushing it forward, the car just stopped like something was under one of the tires. (There was no "clunking" noise, it was just a sudden stop.) Then it was fine again. It just felt as though something was dragging in N.
EDIT: C) The main reason for that test drive was because I was having trouble with the 50-WOT auto down-shift. It was delaying for some reason on my last two drives. I would be at a steady 50mph cruise, then I would go to 100% WOT and the tranny would not downshift immediately like I am used too feeling. It just delayed or one time it did not downshift at all. Then it would be back to auto down-shift again. I had a feeling something was starting to act up but at the time I was concentrating on tuning issues and forgot about it, until now. So I was going to go out and test the auto down-shift at different speeds to see if I could find a pattern.
I can't explain the shifting issue over the keyboard, but I did not even leave my neighborhood because of the way it acted. I can say that I had the car in 1 (under 20mph) and then I manually shifted it into 2 then as I was slowing down, the engine started making a louder sound as though there was slipping (EDIT: previously I said a drag) so I stopped and put it in P and got out to look under the car. (I never made it into D) I did not see anything but I was too worried to leave the neighborhood, so I turned around and drove back to the house under 20mph in 2. It drove fine but it seemed to shift weird on the way back. I think that I am going to pull the pan to check the condition of the fluid and the filter. While it is off, I will check the band adjustments while I have the pan off. If I do not see anything obvious, then I might pull the VB to see how dirty the inside passages are. I have a few minor leaks that I will take care of too.
With these VERY VAGUE descriptions, does any gut feeling come to mind that I can check out once I have the pan off?
Thanks to all!
EDIT: The seal at the output shaft (where the drive shaft goes in) is leaking. Can this seal be replaced after the drive shaft is removed with the housing mounted in place?
Thanks again.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: 727 Debug Questions
[Re: Dodgem]
#1305125
09/17/12 07:26 AM
09/17/12 07:26 AM
YO7_A66
Indiana
I was in a hurry when I wrote that up but I remembered this thought this morning. The main reason for that test drive was because I was having trouble with the 50-WOT auto down-shift. It was delaying for some reason on my last two drives. I was going to go out and test the auto down-shift at different speeds to see if I could find a pattern. I added this to my original post, does this lead to a loose band? Thanks for your reply.
[Re: JohnRR]
#1305127
09/17/12 11:12 AM
09/17/12 11:12 AM
YO7_A66
Indiana
Thanks John. The seal is now on order.
Dodgem: I found this on the 904 thread: ""Then back front band off 1 3/4 turns if it's too loose it will slip into second. rear band same but back it off 2 1/4 turn"" Is this the same outward adjustment for the 727 too? I want to check both band adjustments. Thanks
[Re: Dodgem]
#1305129
09/17/12 02:39 PM
09/17/12 02:39 PM
YO7_A66
Indiana
Thanks Dodgem. I have decided to check the current setting of the front band first. I will count how many turns out it is and if it is too loose, I will reset it to 1-3/4 turns out then test drive the car. If it still acts up, then I will pull the pan and proceed from there. I have printed out your picture just in the case that I need to open up the pan.
I need to replace the extension housing seal to while I am under there. I will reply back once I know how many turns out mine is currently to see if that explains my current issue. thanks again.
[Re: YO7_A66]
#1305130
09/18/12 12:56 PM
09/18/12 12:56 PM
YO7_A66
Indiana
"" I will reset it to 1-3/4 turns out then test drive the car."" I have the car up on stands and the linkage and the cooler lines are out of the way. I can now access the adjuster and hopefully tonight, I am going to tighten the adjuster in until snug while counting the turns, then back it out 1-3/4 turns. Then I will know if the current setting is causing my auto kickdown issue. But I do have a couple of quick questions: A) I have seen instructions to turn out the front band 2 to 2-1/2 turns out from snug too. What causes the different turns out? Why would one source call for a looser setting than another? I assume that if it is setup too loose, then as the band wears the mechanism runs out of stroke. I also assume that if it is too tight, then it will drag.
B) How often do you guys check your band settings on your weekend drivers or on your race cars? The last time that I checked mine was about 4 years ago and it was loose at that time too causing the same conditions. I ended up putting in the stronger link arm at that time and I reset it to what ever my TF2 instructions call for. I am going to find those notes tonight for a reference. Just curious. Thanks
[Re: YO7_A66]
#1305131
09/18/12 01:10 PM
09/18/12 01:10 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
2 - 2.5 is after tightening it to 72 in/lbs.
[Re: JohnRR]
#1305132
09/18/12 01:48 PM
09/18/12 01:48 PM
YO7_A66
Indiana
I have seen where opinions say to adjust it from 1-3/4 turns to 2-1/2 turns out from the snug or 72"/lbs rating. I am just curious what this broad adjustment range will do. I have a 3.8 arm if that matters. Thanks John
[Re: YO7_A66]
#1305133
09/18/12 08:50 PM
09/18/12 08:50 PM
YO7_A66
Indiana
I turned in the adjuster until I hit 72"/lbs and I counted 2-7/8 turn. I assume that this is enough to cause my cruise to WOT slipping?
(Note: I checked my notes and it was six years ago since I last checked this adjustment and at that time I show that I turned it 2-1/2 turns out.)
Tonight, I turned it back out 1-3/4 turns from 72"/lbs, so I am right at 1-1/8 turns tighter now than I was.
Is Dextron III ok to put into this tranny? I need to recheck the level and I want to make sure that I have the right fluid. Thanks again.
[Re: Dodgem]
#1305135
09/19/12 07:42 AM
09/19/12 07:42 AM
YO7_A66
Indiana
My torque wrench is a clicker that I used all of the time. I started with an open end wrench and got it snug (but I could only put three fingers on it due to the space restraints). I had issues with getting my hand up there to get a good grip, so I put the torque wrench on it. It turned about another 1/2 turn at the most to get the 72"/lbs. Within 1/4 turn outward, the screw got easier to turn.
I rolled the car back and fourth in N last night and it rolled freely.
Would the 2-7/8 turns out be enough to show slipping? (I did not realize that it was 6 years since I last made this adjustment.)
What happens if this band adjustment is too tight? thanks allot.
[Re: YO7_A66]
#1305136
09/19/12 09:54 AM
09/19/12 09:54 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I think you have worse problems than band set. sounds like you have a decent inch pound torque mine over tighten another 3 turns before they click. you will be fine. If the band is too tight won't move in drive. sounds like your Torque wrench is about right. Same as wrist snug tight try it if it still slips then air test.
[Re: Dodgem]
#1305137
09/19/12 10:48 AM
09/19/12 10:48 AM
YO7_A66
Indiana
""I think you have worse problems than band set."" Can you elaborate on this? thank you
[Re: YO7_A66]
#1305138
09/19/12 11:29 AM
09/19/12 11:29 AM
JohnRR
U.S.S.A.
A little less than a 1/4 turn loose I don't think is enough to cause slippage on a down shift.
What the history of the trans , what is the band material of the front band , if you know ?
[Re: JohnRR]
#1305139
09/19/12 11:45 AM
09/19/12 11:45 AM
YO7_A66
Indiana
I found the front band adjustment to be at 2-7/8 turns out from 72"/lbs (just shy of 3 turns out). I then reset it to 1-3/4 turns out from 72"/lbs. I put in a new band from A&A six years ago when I made the last band adjustment (2-1/2 turns out). I also put in new clutches about two years prior to that. Thanks
[Re: Dodgem]
#1305141
09/19/12 03:29 PM
09/19/12 03:29 PM
YO7_A66
Indiana
What in my description points to the sprag failing? All I did was reset the front band adjustment. I honestly don't know, that is why the question. Thanks
[Re: Dodgem]
#1305143
09/19/12 04:07 PM
09/19/12 04:07 PM
YO7_A66
Indiana
Got it! Thank you. Should I test drive the car after resetting the front band, or pull the pan and take a look inside? Thank you!!
[Re: JohnRR]
#1305145
09/19/12 04:26 PM
09/19/12 04:26 PM
YO7_A66
Indiana
I will do so. Thank you again.
[Re: YO7_A66]
#1305146
09/20/12 08:12 PM
09/20/12 08:12 PM
YO7_A66
Indiana
UPDATE: I started up the car and while waiting on the temp to come up, the tranny starting BUZZZZZZZZZZ! I knew what that meant so I put it in N to finish the warmup and found the tranny to be 1-3/4 quarts low on fluid It would not even read on the dip stick. After I got the fluid level up, I drove the car forward and backward in the drive (slight incline) without any issues. Then I took it for a drive and it drove fine. I only got it up to around 45mph or so and I did not get on it because I just wanted to see if it would automatically shift/downshift at a cruise/at a stop. I also replaced the extension housing shaft seal and I wanted to get back to the garage to see if I had any leaks. No leaks and over the weekend I will drive it harder to see if the tranny is good to go. Note: This is with the front band set at 1-3/4 turns out from 72"/lbs. Thanks to everyone!! EDIT: Note: I have had a slow dripping leak at the extension housing seal for a while that I have ignored. Since it has been six years since I dropped the pan, I have forgot about the general maintenance of the tranny. This leak must have finally allowed too much fluid to drip out which seemed to be the major culprit of this issue. I now have a new extension housing seal, the front band readjusted and the proper fluid level. Besides the obvious help from the tranny guru's on this sight, I came across a diagram that I found that was helpfull in trying to understand the replies to my thread. See attached for a good diagnostic reference chart. I know that it says loadflight, but it is still a good general reference. If I ignored my tranny like this, just imagine what the condition of my windshield wiper blades must be in.
[Re: YO7_A66]
#1305147
09/23/12 05:40 PM
09/23/12 05:40 PM
YO7_A66
Indiana
Update 2: I got a chance to drive the car today and I need some more help. The GOOD: The tranny auto downshifted and upshifted perfectly at all times (light throttle and WOT). Idle to 100% WOT was excellent. 50-WOT was excellent. Auto downshift when coming to a stop, no problem. Overall the tranny shifted great. The BAD: I started up the car from a cold start IN PARK and about 30 seconds into high idle, a loud noise was coming from somewhere up front. Note: This is the same loud noise that I heard on the last startup that I thought was due to the low fluid. This is the same noise that I heard (before I tightened the band and added the fluid) when I was driving thru the neighorbood in 2 (apx 20mph) and was slowing down to a stop. The noise is hard to explain but it was like a whining noise that even sounded like a vibration. I could not locate the exact place, but it was somewhere up front. I shut the car off and let it set for about 15 minutes then I restarted the car in N. No noise in N this time so I took my test drive. This has me stumped. The tranny acted great while driving, but it makes a really loud noise on cold startup in PARK (just like last time when I thought it meant low fluid.) NOTE: I FOUND THE PROBLEM WITH THE CAR LOCKING UP IN NEUTRAL. The reason that I could not move the car in N was because my passenger rear brake shoe was dragging REAL badly. I need to put a rebuild kit on the adjuster. The car locked up on me again today after my drive when I put it into N, and I thought that it was the tranny again. I disconnected the drive shaft and it spun fine in N. Then I found the rear brake locked up. So this locking up in N issue is no longer,,, I hope. What do you think? Is there a chance that I might have a clogged filter causing the noise on startup?
[Re: YO7_A66]
#1305148
09/23/12 08:40 PM
09/23/12 08:40 PM
Posts: 15,487 Florida
scratchnfotraction
it will not pump fluid in park,do the start up in N so it is pumping fluid and fills the TC and lubes everything. see if you have the noise doing it this way. I have a habit of starting all of my mopars in N. comes from TC drain back problems. it needs to fill the TC before moving. less time waiting for it this way.
[Re: scratchnfotraction]
#1305149
09/23/12 09:03 PM
09/23/12 09:03 PM
YO7_A66
Indiana
Scratch: I have always started it in P and then moved it into N for a few seconds before I leave. I will try starting it in N to see what happens. Thanks
[Re: YO7_A66]
#1305150
09/29/12 11:04 AM
09/29/12 11:04 AM
YO7_A66
Indiana
I decided to go ahead and pull the pan and found a very clean pan for not checking it for six years. I readjusted the rear band to 2-1/4 turns from 72in/lbs and put in a new pan gasket. This is the plastic piece with o-rings. After filling the pan with 4 quarts of Dextronn III, I started it up in N and no noise. I took it for a short test drive and topped off the fluid. Then this morning I started it up again in N with no noise. I just got back from my second test drive and the tranny is acting fine. Several WOT downshifts, a few manual shifts and allot of stop and goes and it acted fine. Thanks again to you members. My tranny has no more leaks and it shifts great!
[Re: YO7_A66]
#1305151
11/07/12 10:24 AM
11/07/12 10:24 AM
YO7_A66
Indiana
UPDATE: My last post stated that I test drove the tranny and it tested fine even through several WOT runs. Well, a couple of weeks went by and I pulled the car out of the garage and then tried to bring it back in and it was slipping again. Then once I got it into the garage and I shut it down, I tried to roll it forward and it locked up again in N. Then like last time, once I rolled it backwards about a foot and then rolled it forward again, it moved freely in N. I decided to email Rick Allison at A&A (He is local to me and I already have some of his parts in this tranny) and after giving Rick all of the details that I posted above and then the additional info of what happened over the weekend, Rick too ( like above mentioned) thinks that the sprag may be damaged causing the binding in N. But Rick also thinks that the slipping (I also have a vibration during cold startup in N) may be my eight year old converter too. I have decided to pull the tranny and let Rick go through it and determine all of the issues. It will be a few weeks before I get a chance to pull it but once he has gone thru it, I will post the damage results. Rick sells the sprag upgrades and he has already quoted me a 9-1/2" converter back in the Spring. Depending on the cost of this, I might consider one of his valve bodies too.
It appears that I have a Winter project!
[Re: YO7_A66]
#1305152
11/25/12 06:45 PM
11/25/12 06:45 PM
YO7_A66
Indiana
I have the tranny out and it is ready to go to A&A. But while the converter was out and laying down, I stuck my fingers down into the inside and I tried spinning the inner housing and it sqeeled as I turned it with my fingers. It also had some drag too. I am going to assume that this inner housing should not be sqeeling and that there might be some damage to the converter. If so, then this might be one of the two issues. This might be the cause to my noise at a cold startup and the reason for the slipping in the forward gears. I hope to drop off the tranny this week and wait for the results. Does the above sound like a converter issue? Thanks
