Window track lube #1304472
09/15/12 11:29 PM
09/15/12 11:29 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I am looking for the name of the grease that is very silky and smooth, grey in color. It is inside my power window motors where the gear is, and a small packet is supplied with new plastic gear, but not labeled. I would like to clean out the tracks on all four and re-lube with this stuff as I believe it is better than bearing grease, which I have used before. I guess the bearing grease requires some heat to work best, and in the winter really hardens up. Anyone know what the grease I am describing is called? Thanks.
Facts are stubborn things.
Re: Window track lube [Re: larrymopar360] #1304473
09/16/12 09:37 AM
09/16/12 09:37 AM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
I use "Door Ease" . It comes in a 4" tube. You should be able to get it at your local parts store.
Re: Window track lube [Re: larrymopar360] #1304474
09/16/12 09:39 AM
09/16/12 09:39 AM
scratchnfotraction Offline
white litheum(sp?)greese
