Re: removing stainless windshield and back glass trim
[Re: 69fish]
#1302333
09/11/12 09:56 PM
09/11/12 09:56 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Google it. I haven't checked but there are probably videos to watch.
Still looking for LM29H1B415501, '71 Demon 340
[Re: 69fish]
#1302334
09/12/12 10:13 AM
09/12/12 10:13 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
There is a little tiny lip on the bottom of the trim, the retainer clips latch onto that. The tool neeeds to slide in between the body and the lip, it will push the lip out away from the trim, lift up the trim with your other hand and maybe use a thin screwdriver to slide in between the trim and the gasket to lift the trim up, do one clip at a time and make sure all of them (retaining clips) are disconnected from the bottom of the trim pieces. There is three or four pieces of trim, if I'm remebering correctly IHTH
[Re: Challenger 1]
#1302336
09/12/12 11:15 AM
09/12/12 11:15 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Is his 69 the same as 70-74 challengers?
Same style clip but rubber gasket instead of glue in glass. OP. Be carefull and slow. You don't want to bend up that trim either. Pretty hard to find and $$$. Use a thin piece of card board between tool and rear glass. It takes abit of practice and patience to get the hang of it.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1302337
09/12/12 12:59 PM
09/12/12 12:59 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
And I've found that teh amount of corrosion, goo and debris in there makes each clip require a slithgly different technique before it finally releases.
[Re: moparmarks]
#1302338
09/12/12 01:57 PM
09/12/12 01:57 PM
Challenger 1
Cincinnati, Ohio
I took these pictures a couple years ago to help folks know what there trying to do. This is a challenger, though. A slighty modified "slim jim" lockout tool. Remember them?
[Re: west]
#1302341
09/13/12 02:13 AM
09/13/12 02:13 AM
Cab_Burge
I paid a local glass company guy $50.00 to come out and remove the trim, front and rear, from my Duster for painting last winter, he was suppose to come back and reinstalled it after the paint job, he didn't I ended up installing it myself Not hard either
[Re: 69fish]
#1302344
09/24/12 12:04 AM
09/24/12 12:04 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
