Page 4 of 6 1 2 3 4 5 6
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: ScottSmith_Harms] #1301402
09/18/12 04:42 PM
09/18/12 04:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Can you take a really good shot of each complete muffler square on, as well as another shot of the stamped numbers close up, straight on?
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: ScottSmith_Harms] #1301403
09/18/12 07:51 PM
09/18/12 07:51 PM
Virginia's Eastern Shore
dmoore Offline OP
dmoore  Offline OP
Scott, The mufflers & tail pipes were replaced a few years ago.....sorry to disappoint!
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1301404
09/18/12 08:01 PM
09/18/12 08:01 PM
dmoore Offline OP
dmoore  Offline OP
This is the detail that did it for me....the blue dipped tension spring on the warm up valve shaft...incredible!
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: NV69B7RR] #1301405
09/19/12 01:47 PM
09/19/12 01:47 PM
dmoore Offline OP
dmoore  Offline OP
Keep the pictures coming!! Man that car is georgeous!! I could spend hours looking over that car at a show.
Can I make a picture request?
1) One that shows the top of the grille & the headlight bezel mounting fastener
2) Where the engine to firewall ground goes. Looks like the wiper motor to??
No problem Brent...passenger side
Drivers side......
Ground connection radiator support near battery...
Wiper ground detail.....
If you need anything else just ask
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1301406
09/19/12 02:00 PM
09/19/12 02:00 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, not dipped, just dripping with paint. It was painted along with the engine and exhaust manifolds, being suspended a bit in mid air away from the high heat it didn't durn off like all the paint surrounding it.
Any chance some of your suspension parts were painted over in black, as if to detail them? What color (black paint or natural metal) are the following:
Tie rod sleeves
pitman arm
idler arm
tie rod ends
strut rods
upper a-arms
lower control arms
steering box
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: ScottSmith_Harms] #1301407
09/19/12 06:20 PM
09/19/12 06:20 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
The torque converter, flex plate, and bolt all look to be painted light blue.
Is that the same light blue engine color? I've recently seen something similar to this on a 69 340.
Was the motor painted with the torque coverter installed?
Just wondering how the torque got installed in order of the engine assembly operations.
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: ScottSmith_Harms] #1301408
09/19/12 08:21 PM
09/19/12 08:21 PM
dmoore Offline OP
dmoore  Offline OP
Tie rod sleeves
pitman arm
idler arm
tie rod ends
strut rods
upper a-arms
lower control arms
steering box
I have talked to all owners & no one at any time painted or touched-up anything.....and...I have found no evidence that they were wrong...phenomenal car that's had phenomenal care.
Tie rod sleeves Natural
pitman arm Natural
idler arm Natural
tie rod ends Natural
strut rods Painted black
upper a-arms Natural
lower control arms Painted black
steering box Natural (alum)
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: autoxcuda] #1301409
09/19/12 08:24 PM
09/19/12 08:24 PM
dmoore Offline OP
dmoore  Offline OP
Yes, it is the same color as engine which was standard fare...It had to be painted prior to installation.....
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1301410
09/20/12 01:34 AM
09/20/12 01:34 AM
So Cal
So Cal
Could you get this spray pattern below if you painted the flex plate and torque converter installed.
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: autoxcuda] #1301411
09/20/12 09:33 AM
09/20/12 09:33 AM
dmoore Offline OP
dmoore  Offline OP
Are you asking or telling?
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1301412
09/20/12 09:39 AM
09/20/12 09:39 AM
dmoore Offline OP
dmoore  Offline OP
Tie rod sleeves
pitman arm
idler arm
tie rod ends
strut rods
upper a-arms
lower control arms
steering box
pitman arm Natural
idler arm Natural
Scott I made a mistake on the tie rod sleeves, they were painted black, sleeves only!
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1301413
09/20/12 09:45 AM
09/20/12 09:45 AM
dmoore Offline OP
dmoore  Offline OP
Let me be the first to thank you Dmoore for posting the pics on these low mileage, survivor cars, personally i savor every detail. I have a question on the ceramic resistor on the wiper motor, was that painted over by the factory or is that undercoating? Thanks again..
The complete wiper motor assy was painted on this particular car to include the resistor and the copper & brass I.D. tags unlike the yellow & white cars. I'm not sure why at this point...Note the wide undercoat treatment around the blower motor/wiper holes.
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1301414
09/20/12 11:45 PM
09/20/12 11:45 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Fabulous looking car Dave, wow!
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: 69Cuda340S] #1301415
09/21/12 09:00 AM
09/21/12 09:00 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Thanks for the pics, even though they all help!
What re your plans with this Duster? Drive it, Keep it, race it
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: 69Cuda340S] #1301416
09/21/12 02:14 PM
09/21/12 02:14 PM
dmoore Offline OP
dmoore  Offline OP
Thanks Bill! How's the Cuda?
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: NV69B7RR] #1301417
09/21/12 02:17 PM
09/21/12 02:17 PM
dmoore Offline OP
dmoore  Offline OP
Your certainly welcome! And, yes, yes & Noooooooooooooo!
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1301418
09/21/12 07:48 PM
09/21/12 07:48 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I emailed you some pics...
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1301419
09/22/12 11:32 AM
09/22/12 11:32 AM
So Cal
So Cal
Asking.
In your picture the torque converter, flex plate, and bolt are all blue.
Did that get painted blue at the same time? I'd think that would mean it was installed on the engine. But was there a different process? Did that not actually get painted together?
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: autoxcuda] #1301420
09/23/12 12:01 PM
09/23/12 12:01 PM
dmoore Offline OP
dmoore  Offline OP
Steve, I can only guess the flex plate & converter were shot after being installed on the engine...would make more sense...explains why there was spotty coverage in some area's.....
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: NV69B7RR] #1301421
09/23/12 03:34 PM
09/23/12 03:34 PM
dmoore Offline OP
dmoore  Offline OP
Brent, This shows the single ground wire between the wiper motor and blower motor....
