Re: Edelbrock accelerator pump adjustment question
[Re: RapidRobert]
#1300565
09/17/12 07:30 PM
09/17/12 07:30 PM
Posts: 738 OK
David_Trimble
OK
Well, after doing some searching and measuring this is what I've found out: I need a washer that's 7/16" OD and 5/16" ID (and at this point, you're probably beginning to see the problem). But the closest SAE standard washer I found was a #8 washer that would work on the OD but I'd have to drill out the ID to work. This is beyond what I could do with a drill press (I'm not able to come up with a way to safely hold down the washer while I drill) so I'm beginning to think I need to sleeve it instead. Failing that, that remaned distributor at O'Reilly's is starting to look pretty good...
'69 Dodge Charger R/T
[Re: David_Trimble]
#1300570
09/19/12 07:09 PM
09/19/12 07:09 PM
Posts: 738 OK
David_Trimble
OK
Well I don't know how I did it but I managed to make a washer that would fit And it fits perfectly (I can't get over how lucky I was) - after I managed to get the clip back into place (I spun the clip around a turn or 2 to make sure it was in and seated) I measured the end play and got around .005". No more slop - and there's no interference from the centrifugal advance that I can tell- it operates pretty smoothly by hand. I'll oil the mechanism (it was pretty dry when I took it apart) and should have the distributor together and back in the engine before the weekend.
[Re: scratchnfotraction]
#1300572
09/20/12 08:03 PM
09/20/12 08:03 PM
Posts: 738 OK
David_Trimble
OK
Well I started reassembling the distributor today and when I got to the point where I could install the retaining collar on the lower shaft I noticed that the holes had elongated. Not by much but enough where if I'm going to do this right I might as well replace it. There's no friction fit between the pin and the collar- because of that it's hard to tell if I have correct end-play. The only place I know of to get a new collar is a dealer, and I know it'll have to be ordered- so it looks like the distributor's not going in this weekend Edit- After looking at it again I see that the pin is a friction fit in one of the holes in the collar- but the other hole is fairly loose. If I have to I probably could live with this, but to be sure I'll replace it if I can....
[Re: RapidRobert]
#1300574
09/20/12 09:32 PM
09/20/12 09:32 PM
Posts: 738 OK
David_Trimble
OK
Cool- I'll check out Lowes this weekend of the dealer fall through then. Thanks!
[Re: RapidRobert]
#1300576
09/22/12 06:42 PM
09/22/12 06:42 PM
Posts: 738 OK
David_Trimble
OK
Ok, first of all I did manage to find a couple of nylon bushings at Lowes that will work if need be. I called the dealer Friday about the collar kit but I'm told that the part number isn't coming up as being valid on the parts system, so it's no longer available (big surprise)
However, I took another look at the original collar and I think it's actually ok- I'm going to go with it and if it turns out that it's got to be replaced, well I now have some collars that could do the job.
My current question though: when reassembling the collar on the shaft I took a measurement of the end-play of the lower shaft and got a pretty low number- .002-.003. Plus I could feel a slight binding going on when I turned the lower shaft, so I took it all apart and looked again. I noticed that the upper bearing in the distributor body seems to sit up higher out of the 'floor' of the distributor body than I thought it should- about 1/8-1/4" above. This may or may not be correct, I don't know- I would've thought the top edge of the bearing would be more or less flush with the floor.
But to be sure, I thought I'd ask first to see if that's ok because if it isn't, it might explain the binding and small end-play. But if it is, then I'm wondering if I can eliminate one of the two washers that's under the centrifugal assembly, to try to get a little more end-play and less binding.
But if those two washers needs to be there though, is there anything else I can do to increase the end-play?
David
