Re: Another --How much HP?---Engine dyno--416 stroker post
[Re: BPE]
#1299479
09/19/12 09:11 AM
09/19/12 09:11 AM
Posts: 458 Michigan
BPE
I will say 583 hp and 552 tq. But whatever the numbers are I hope it does what you want in the car.
Rod
Well if you get your extra 20 hp and 15 ft.lbs. My guess was pretty much dead on.
Rod
[Re: Dunnuck Racing]
#1299481
09/19/12 05:30 PM
09/19/12 05:30 PM
Posts: 1,048 The Great White North
RAMM
Picked up some fresh pump 91 and pulled it a few more times. Current new bests are 570 hp and 556 ft/lbs. I haven't found the sweet spot with timing yet --I think it wants 2 degrees more.
I have to find best timing, add the mufflers, play with lifter pre load and try a .5" spacer.
So far it's pretty stout for a 10.3 comp small block. It has almost 460 ft/lbs @ 2500 rpm but has a bit of lull in the curve, I'm hoping the mufflers help this some. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1299483
09/19/12 08:28 PM
09/19/12 08:28 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Nice Job Jesse!!!! You need another 10 hp and 4 ft/lbs and I win.
By the way what do I win again? Matt
[Re: MattW]
#1299484
09/19/12 08:48 PM
09/19/12 08:48 PM
RAMM
I believe another 10 hp and at least 5 ft/lbs will be attainable. I can offer you a Get out of Jail free card. J.Rob
[Re: RAMM]
#1299487
09/20/12 08:06 PM
09/20/12 08:06 PM
RAMM
How do you think the self learning EZE -EFI did? J.Rob
[Re: RAMM]
#1299490
09/20/12 09:08 PM
09/20/12 09:08 PM
RAMM
Overall I'm impressed with the FAST EZE-EFI.
It did everything it was supposed to do (and a few other things too)
Here it is. J.Rob
[Re: RAMM]
#1299492
09/20/12 09:31 PM
09/20/12 09:31 PM
Posts: 1,784 PA
W5DART66
PA
I would like to see the cam in advanced 2-4 more if you have not tryed that.....
Injection did way better then I thought most of the people that did TB inj. Was way down vs good carb.
What rule for carb/ intake this year? ( I am lazy could look it up)
[Re: Performance Only]
#1299496
09/20/12 11:31 PM
09/20/12 11:31 PM
RAMM
It probably will actually. Although I'm not sure when. You see, I've been doing this EMC thing since 2009 and I have sold every engine or engines using most of the same components used in the contest.
To be honest--Yes, I think it will make it to the track and I will report the results good or bad--no excuses. I think it will run a low 11. But wait!! Is that in a JR. dragster or in a full body door slammer. J.Rob
