Another --How much HP?---Engine dyno--416 stroker post
#1299419
09/07/12 09:39 PM
09/07/12 09:39 PM
Posts: 1,048 The Great White North
RAMM
Here's the rundown:
360 block/half fill/line honed/decked, yadda yadda yadda.etc....
4" stroke 4340 Eagle crank with SCAT 6.123" rods Icon 745's with a final static comp ratio of 10.5
Heavily worked EQ Magnum heads with 2.08"/1.60" flow 303-304 @ .630" with a min CSA of 2.35" (wasn't easy)
Eddy SV with plenum work and port match .5 open spacer Holley 830 or 1000hp with annulars
Hydro-roller 108 LSA 250/252 @ .050" .660"/.590" design (not actual)
Schoenfeld 1 5/8" 1 3/4" step headers with a 3.5 to 3" hillbilly merge collector.
I have a great deal of faith that this combo will produce great power for what it is--What say you Moparts? J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: Another --How much HP?---Engine dyno--416 stroker post
[Re: W5DART66]
#1299421
09/07/12 10:04 PM
09/07/12 10:04 PM
RAMM
Don't know yet but soon, very soon.
Gotta love ya Brett!
I like your guess (more like estimate) on HP but am searching for about 20 more ft/lbs.
At this point I am just really curious if I can get the FPS on the small ports down enough to get this many cubes to rpm enough. J.Rob
[Re: W5DART66]
#1299422
09/07/12 10:43 PM
09/07/12 10:43 PM
Posts: 3,695 nc
emarine01
nc
603HP 546TQ. What do I win.....
Hey... That was my guess
[Re: RAMM]
#1299424
09/07/12 11:06 PM
09/07/12 11:06 PM
Posts: 2,091 Delray beach, Florida
Performance Only
so a couple are thinking along the lines of 1.45 hp/ cube. i would expect a bit less, more like 1.2hp/ cube. small HR cam with a small port will make great torque.
machine shop owner and engine builder
[Re: Performance Only]
#1299426
09/07/12 11:16 PM
09/07/12 11:16 PM
Posts: 1,784 PA
W5DART66
PA
I say small port makes poor TQ (peek) and just not good for much of anything air speed in port just kills HP AND TQ. I may have been tick aggressive on both my numbers on Robs dyno but I bet he gets close to the 600 HP.
#1299428
09/08/12 08:40 AM
09/08/12 08:40 AM
RAMM
I am not sure if I will reach the 600hp benchmark with these heads; however, I am confident it will come very very close.
Dan--What would you consider a large hydraulic roller? J.Rob
[Re: fishy340]
#1299431
09/08/12 09:45 AM
09/08/12 09:45 AM
Posts: 1,784 PA
W5DART66
PA
i'd say low 500's comp is real low
My engine masters 390 CI made 660 with 10.75to1...
[Re: W5DART66]
#1299433
09/08/12 11:26 AM
09/08/12 11:26 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
o yea my indy junk made 700 w 950 carb on 93 octane na na lol
