Re: KOS CARS
[Re: old yeller]
#1298483
09/09/12 07:07 AM
09/09/12 07:07 AM
Posts: 4,066 Mo.
racerx
Mo.
NONE of these KOS cars ran the #,s on a true 10.5 tire..KOS rules were built around a certain group of azz kissers...just keeping it real!!
bird!
Bird......what do u consider a true 10.5?(28's/29.5's)
Re: KOS CARS
[Re: racerx]
#1298484
09/09/12 07:33 AM
09/09/12 07:33 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Bird again you are full of Bull.
For years KOS was one class Super Street. The rule was 28X10.5. How do I know. I had a 28X11 Goodyear and was not allowed to run.
KOS SS was generally following the rules of NMCA SS and later we were allowed 29.5X10.5. Then by the year 2001 allowed 31X10.5W and then following NMCA, sense a lot of us ran both classes, KOS followed allowing 33X10.5W, but with a weight penalty.
EZ street ran smaller tires. Later they, following NMCA's Easy Street class they too stretched the tire rules to larger than 28X10.5.
Mucle Street was smaller. I think a 28X10.5 street tire or equivalant was their rule.
Bird, KOS was ran from the early 90's all the way to the last year in 2005. We ran MSD 7AL boxes with a retard box and no progressives or timed timing controllers. So why are you trying to diss the series? For those years it was what it was. No TT5 as you comment in the later years, but we ran by rules which were more restrictive than any of the classes ran for Heads up street cars today.
Never winning a round of KOS racing is no reason to run it down. A series where many people met a lot of freinds, saw their car on ESPN or in the mags for the first times.
Bird I take up for you all the time but BS statements like this is why a lot of people don't care for you.
Leon
Re: KOS CARS
[Re: old yeller]
#1298485
09/09/12 08:00 AM
09/09/12 08:00 AM
Posts: 806 Kentuckian
sixpakx
Kentuckian
i'm sorry.,but you have to agree andy mayes kicked azz..luv that guy to this day!!
Andy was fast, but one of the KOS races at clay city (I WON ), I took Andy out in the finals, he has a backfire
Re: KOS CARS
[Re: Mulehead]
#1298490
09/09/12 11:56 AM
09/09/12 11:56 AM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I miss all of these KOS cars also. Sure seems like alot of them were running bigger than a 10.5" tire. (even if W's).
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: KOS CARS
[Re: 6PKRTSE]
#1298491
09/09/12 12:16 PM
09/09/12 12:16 PM
Posts: 147 Ohio
R/T BRAD
Ohio
In EZ Street it had to be a DOT Tire. I dont think anything more than a 11 inch street tire was allowed. We used 315 BFG's on ours because thats what we used in the NMCA/NSCA T/A Class.
Re: KOS CARS
[Re: one bad fish]
#1298492
09/09/12 02:07 PM
09/09/12 02:07 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
This topic is good keep on with it. Love the storeies. And like I said someone needs to start this class again
Whats the difference between this and the 10.5 class that we run in your opinion other than the name....which we are switching to as long as Im not stepping on anyones toes.
We dont have a ton of rules, but I think the way we are set up its a pretty level playing field for the number for cars that we have. Open to Mopar powered, Mopar door cars only 1/8 Mile, Heads Up, .400 Pro Tree, 16 car field / blind draw Rear Tires 29.5 non w or 315 radial (29.5″ tall tires allowed up to 10.5 for a slick and 13.5 in a dot street tire) Must retain stock fire wall and front frame rails in stock location, aftermarket bolt on front suspension allowed Any rear suspension allowed Wheelie bars allowed Backhalf (aftermarket rear frame rails) allowed Stock appearing interior (stock style dash, can be fiberglass) Any power adder allowed Weights:
Boosted big block 3300lbs Boosted small block 3100lbs Nitrous big block 3100 Nitrous small block 2900 N/A big block 2800lb N/A small block 2600lbs (Deduct 50lbs for Leaf Springs) (Deduct 100lbs for the following cylinder heads: Indy EZ, Indy SR, Bulldog, Edelbrock, 440 Source, Mopar Performance, Pro Comp) (Deduct 50 lbs for Stock Factory Iron Block)
Re: KOS CARS
[Re: joshking440]
#1298494
09/09/12 05:01 PM
09/09/12 05:01 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
We dont have a ton of rules, but I think the way we are set up its a pretty level playing field for the number for cars that we have. Nothing at all Josh just that the KOS went all over to all the mopar shows don't get me wrong what u doing is bad azzzz to. Bring the race to etown Open to Mopar powered, Mopar door cars only 1/8 Mile, Heads Up, .400 Pro Tree, 16 car field / blind draw Rear Tires 29.5 non w or 315 radial (29.5″ tall tires allowed up to 10.5 for a slick and 13.5 in a dot street tire) Must retain stock fire wall and front frame rails in stock location, aftermarket bolt on front suspension allowed Any rear suspension allowed Wheelie bars allowed Backhalf (aftermarket rear frame rails) allowed Stock appearing interior (stock style dash, can be fiberglass) Any power adder allowed Weights:
