Re: Reserection of my old W8 Bullet
[Re: 408strokerdart]
#1296655
09/04/12 04:42 PM
09/04/12 04:42 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Glad to hear you are getting closer to getting back out there. Look forward to hearing the results of all the new changes.
[Re: jim sciortino]
#1296659
09/04/12 09:29 PM
09/04/12 09:29 PM
Posts: 3,456 Out West
408strokerdart
Out West
Looks good.....
What rpm range are you planning for this deal???
8000 to 8200 max Jim. New cam will make more torque than the old one.
#1296660
09/04/12 09:50 PM
09/04/12 09:50 PM
Posts: 6,130 Melbourne , Australia
LA360
After all of the trouble you've had, I would have put it on a Dyno! I hope it all goes well, lesser people would have thrown in the towel long ago!
Alan Jones
#1296662
09/04/12 10:24 PM
09/04/12 10:24 PM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
Looks good.....
Are we talking peak HP at 8-8200, or cross rpm???
RPM is ET....in these smallblocks. Converter flash, gear ratio and shift recovery, get it done. With the right hardware, 8000 is not that high these days and should be easy on maintenance.
[Re: jim sciortino]
#1296664
09/04/12 11:06 PM
09/04/12 11:06 PM
408strokerdart
Out West
Looks good.....
I agree with all of that Jim. I will be feeling this combo out and give it what it wants. I'm loving the belt drive as I don't have anything in front of it and I can change/play with cam timing in just a few minutes. Clearances were checked within a range both directions from the installed so I know where I can safely play.
[Re: BigDog68Dart]
#1296665
09/04/12 11:09 PM
09/04/12 11:09 PM
408strokerdart
Out West
looks like you are coming along nicely, Dad is ready to break that thing in for you! you are out of practice and you know i'll take it easy on it!
Yes Dad....alot further than you think.
[Re: Thumperdart]
#1296668
09/11/12 11:31 PM
09/11/12 11:31 PM
408strokerdart
Out West
Lookin good Good you caught the bearing deal. Whats the whole motor combo by chance.
Sorry I really didn't respond to this question Dom, but I will touch on the combo as I post updates of the engine re-assembly. Just my way to keep everyone tuned in.
[Re: SB412DUSTER]
#1296670
09/12/12 12:15 AM
09/12/12 12:15 AM
408strokerdart
Out West
The last pic of the pan whats the little sleeve welded to the pan?
There is one under the kick out on the other side to match. They are for my drip pan to mount to. The drip pan has pins on it and just slide forward to engauge and then dzus into place on the front of the pan.
[Re: SB412DUSTER]
#1296672
09/12/12 12:28 AM
09/12/12 12:28 AM
408strokerdart
Out West
good idea
I just hate diapers and wanted a way that I could still access the bottom easily and pass tech. Plus it isn't just a drip pan....it's a belly pan.
#1296673
09/12/12 12:50 AM
09/12/12 12:50 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Brian, You're smarter than the average mule and his head is twice the size of yours!
I really like that idea. I may have to modify it a little for the cuda. Beep
[Re: Bigbeep]
#1296674
09/12/12 12:52 AM
09/12/12 12:52 AM
408strokerdart
Out West
I don't know about that John....been feeling like an average mule here lately. Good luck at Norwalk if you are going. Wish I was coming up this year.
