SB Fuel Pump Suggestions
#1295627
09/02/12 11:21 AM
09/02/12 11:21 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I am currently shopping for a new mechanical fuel pump and I am looking for suggestions. The last two that I have used have been the Carter M6866, which seem to last 2-3 years. I would like suggestions on other brands, or the nicer Carter units. I am looking for 5.5-7psi units which do not require a regulator. What about the higher priced Carters, MP, Edelbrock or Holley pumps? I don't mind raising the price from my current $33 Carter as long as I am getting a good unit. http://www.summitracing.com/parts/HLY-12-360-11/ http://www.summitracing.com/parts/EDL-1720/ Carter M6902: http://chucker54.stores.yahoo.net/cam6sumefupu.html Thanks
Re: SB Fuel Pump Suggestions
[Re: mcmopars]
#1295630
09/02/12 11:59 AM
09/02/12 11:59 AM
YO7_A66
Indiana
Mc, I am currently leaning towards the Carter M6902, which has the replacable diaphram. Thank you for the reply.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: 5spdcuda]
#1295632
09/02/12 01:39 PM
09/02/12 01:39 PM
RapidRobert
Me too, I used a cheap parts house Airtex? pump on a 360 SB (9:1/2bbl) circle burner (class rules-stock pump required) with 5/16" line and NO fuel starvation at 6200 RPM WOT though I am going to drill out the nipples to 3/8 & 3/8 line
[Re: YO7_A66]
#1295633
09/02/12 02:23 PM
09/02/12 02:23 PM
Posts: 3,916 usa
lewtot184
usa
this is the pump i would use. 3 valve and can be taken apart. the diaphragm is replaceable if you can find one. the mancini rebuild kits are junk!
[Re: YO7_A66]
#1295636
09/07/12 07:41 AM
09/07/12 07:41 AM
YO7_A66
Indiana
I received and installed the Carter M6902 from Mancini last night. I noticed right off that the strength of the spring is much stronger than the spring on the Carter M6866 (one piece) unit that I pulled off. The description of the M6902 pump shows 5.5-6.5psi but my mechanical gauge was showing 7psi plus/minus 1/2 or so. I was watching my float levels and they were right where I set them and my O2 gauges looked good, so the extra 1psi does not seem to bother my floats at idle. I should be able to test drive it this weekend and hopefully this was the reason for my erratic lean conditions that developed out of no where. http://chucker54.stores.yahoo.net/cam6sumefupu.html
[Re: YO7_A66]
#1295637
09/07/12 07:49 AM
09/07/12 07:49 AM
YO7_A66
Indiana
Made In USA! The 6902 shows up in the beginning of the casting part number on the flange.
[Re: YO7_A66]
#1295638
09/08/12 01:18 PM
09/08/12 01:18 PM
YO7_A66
Indiana
The pump was the problem. I no longer have the lean issues and my A/F numbers are steady again. Thanks for the suggestions!
