Re: Mopar Engine experts:Please i need Help!
[Re: twinscrew698]
#1293581
09/04/12 08:22 PM
09/04/12 08:22 PM
Posts: 1,357 central Florida
VL21
central Florida
What does the inside of the cover look like? Start it now. Without the cover. And possibly wrong seal, too deep.
It takes gasoline to interest me.
[Re: 340SHORTY]
#1293583
09/05/12 02:26 AM
09/05/12 02:26 AM
Posts: 1,317 Ohio
jlatessa
Ohio
[Re: VL21]
#1293586
09/05/12 07:17 AM
09/05/12 07:17 AM
Posts: 409 Lexington NC
twinscrew698
Lexington NC
Here is a pic with Timing cover and seal,does not look like it was hitting seal to me..
[Re: 340SHORTY]
#1293587
09/05/12 07:22 AM
09/05/12 07:22 AM
twinscrew698
Lexington NC
iN THE 1 PIC IT LOOKS LIKE ITS ON THE CRANK SNOUT BACKWARDS..
I checked before i took it apart to make sure when i tore it apart to which way it should be and it is on the right way as if i turn it around it will hit timing chain.
[Re: VL21]
#1293589
09/05/12 07:34 AM
09/05/12 07:34 AM
twinscrew698
Lexington NC
Kinda afraid to start it like this,as i would think have oil flying all over the place or water getting down in the oil pan and doing any damage as it takes a few minutes to start the noise, I still plan on changing the oil anyhow afterwards but just being careful! As looking at this Pic it looks like the bottom of seal has a little shine to it also,so it might of been hitting it also!
[Re: stumpy]
#1293592
09/05/12 11:24 PM
09/05/12 11:24 PM
Posts: 2,498 God's Country Maryland
GODSCOUNTRY340
Either the seal was not bottomed out in the cover or the cover is caved in towards the timing gears. Make sure the cover isn't pushed in. The slinger looks to have been installed correctly. If it would have been installed the other way it would have been hitting the chain. I'd say your cover is caved in.
[Re: stumpy]
#1293593
09/06/12 10:51 AM
09/06/12 10:51 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Why not just leave it out. Lots of big blocks around without it.
problem solved,i have never ran a slinger and ever had a prob.
