Re: 1970 RoadRunner SRT8
[Re: KatFysh]
#1292888
11/24/13 04:43 PM
11/24/13 04:43 PM
Posts: 656 Florida
CJD AUTOMOTIVE
AWESOME.. I was "directed" here from the general section.. duuhh me.. I LOVE what you are doing. Not until about 3 weeks ago did I think of looking at wrecked, newer Gen Challengers for my '70 Barracuda.. NOW, I am watching this post like .. Your Barracuda build is/was excellent..This one REALLY has my attention..
I've taken measurements from a 2010 Challenger but have yet to compare them to my '70. Do you think I'd be better off with a Charger over the Challenger if/when I make up my mind to do this.. I've been around a few welders/torches/grinders/frame jigs etc etc to not be afraid to take something like this on..The final product may not be as award winning as yours but I could hang close..
Thanks. I don't know the wheelbase of any of these vehicles off the top of my head, but either platform will probably need tweaking. The LX is an auto trans, and the LC can take a T56 manual, so include that in your decision.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#1292889
11/24/13 09:44 PM
11/24/13 09:44 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
so because you're hacking it apart and have the tubing pieces on the sides, the actual measurements of the donor car doesn't matter much???!!! A friend of mine thought that the Charger would be better to use. Possibly easier to come by, cheaper for replacement parts,etc etc??
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: KatFysh]
#1292890
11/25/13 01:07 PM
11/25/13 01:07 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Sort of... Your not hacking it, you need to drill the spot welds at the front and rear pan joint. Your going to shorten the front pan to accommodate the wheel base. You are drilling the spots where the floor pan connects to the side rails as well. The tubing on the sides becomes the new side rails, so the pans stay intact and the same width as either donor car. I'm sure the LX cars are cheaper simply because they are older.
#1292891
11/25/13 06:08 PM
11/25/13 06:08 PM
KatFysh
Falconer, NY
Don't mean "hacking" in a negative way.. Just a general phrase.. I've seen by your pics {and I know better} that you've drilled the spot welds. That's the only way to do it correctly..I am going to find a Charger and take some measurements of the body panels front to back and side to side for comparison of the Challenger. In the meantime, I'll check online for dimensional measurements {body shop} comparisons between the 2, for shiggels and gits..Do you mind if I ask,inquire,look for advisement,etc etc, in the future with certain aspects of the build if I go this direction?
#1292892
12/04/13 12:05 AM
12/04/13 12:05 AM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
Wow! Unbelievable Craig, thank you for your dedication to sharing this work here in cyber-world AFTER a long days work of fabricating. I'll be calling you soon about an EASY project in comparison to see if you're interested in taking on the job. Thanks again for sharing!
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
#1292894
12/21/13 05:47 PM
12/21/13 05:47 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#1292897
12/24/13 02:34 PM
12/24/13 02:34 PM
KatFysh
Falconer, NY
Will that back glass clear?? Awesome work. Thank you for posting the progress pics. They will be very helpful to many..You are inspiring me, to say the least.. Merry Christmas to you and yours..
[Re: KatFysh]
#1292898
12/24/13 03:13 PM
12/24/13 03:13 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Thanks and Merry Christmas. No the seats will be cut down 4" when it goes to upholstery. The owner new it would be an issue that would require mods. Remember the fuel tank is under the back seat and the LX car has a taller roof (believe it or not!), which is why the rear seat backs sit so tall.
[Re: moparlulu]
#1292901
01/17/14 03:16 PM
01/17/14 03:16 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Between this and your cuda....wow,wow, wow! Awesome fabrication skills!
Thanks! Now lets see which one burns gas first!
[Re: dragula426]
#1292902
01/17/14 03:19 PM
01/17/14 03:19 PM
Posts: 656 Florida
CJD AUTOMOTIVE
this build and the cuda build make myself and the stuff we do seem cavemanish!!!! awesome job!
Thanks, but that car of yours is sweet! A couple of throttle bodies and a Holley HP setup with boost control would make that 496 of yours pure like a kitten!
#1292903
01/20/14 02:39 PM
01/20/14 02:39 PM
Posts: 11 Springfield, MO- USA
Force28x
This is just breathtaking. It's been a while since I harassed you with my inquiries, so... I know that you used the mock-up body/wheels to locate body ride height. Did that also determine wheelbase? Did the LX wheelbase remain the same? If not, where did you take that out of the floor? Did you just overlap front and rear floors until you met the rear suspension position to achieve proper w/b? Sorry, just trying to absorb everything I can. I swear, If I was closer, I would beg for a tour.
[Re: Force28x]
#1292904
01/20/14 04:09 PM
01/20/14 04:09 PM
Posts: 656 Florida
CJD AUTOMOTIVE
No problem. I measured ride height with the stock SRT wheels. Measured overall diameter of the tires of the SRT and what the Roadrunner will use. Subtract this, divide in half and adjust jigs accordingly.
I used the wheels and tires that the RR will use and adjusted front and back in the wheel openings until the owner was happy. That determined the new wheel base. The front floor section sits under the rear and is spot welded from the factory. I took the difference between the two wheel bases and trimmed the front floor section the corresponding amount. Then overlapped it and welded it like the factory had it.
[Re: Force28x]
#1292906
01/21/14 04:27 PM
01/21/14 04:27 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Thanks for sharing that info, one more inquiry and back to lurking... The dash. Did you get a picture from the top when you 'test-fit' the dash? I'm curious about HVAC and if there is going to be some re-routing needed because of the lack of dash real estate. I finally have a frame coming in the next two weeks. I may actually get this thing started this summer. As always, wonderful work and thanks for sharing your experience. John
Yep, you lose about 6" off the front of the dash. The defrost duct will need to be reworked along with ducts or channel added to the dash to blow on the windshield.
#1292907
01/22/14 12:10 AM
01/22/14 12:10 AM
KatFysh
Falconer, NY
how much would the difference in depth be between the RR and the Cuda. I'm thinking that the Cuda would have the needed depth for all that is behind the Charger dash??!! Correct?
