Innovate wideband o2 #1286440
08/16/12 03:19 PM
08/16/12 03:19 PM
PA
bwhackd34 Offline OP
PA
Just got it today....want to install...have Supercomps into 3" x then into cutouts, mufflers, tips out the back.....I have two concerns....
1. I was thinking of putting the sensor in the middle of the x so it gets info from both banks....not really finding any info on locations...seems a lot of Ford guys are putting them in the left collector as that is the side they are known to run leaner.....any suggestions on location?...
2. Anyone with adjustable length Supercomps knows they do not seal 100%.....I have seen info that ANY exhaust leaks will give bad info....it seems they do not leak excessively but I can feel a small bit of leakage from the middle of the collectors.....thought about trying some header wrap but do not know how easy it will be to get in that area anyway......4spd A-body, 1 7/8 primary chassis exit....kinda tight....anyone have any experience with a similar situation?.....
Thanks in advance!
Re: Innovate wideband o2 [Re: bwhackd34] #1286441
08/16/12 04:09 PM
08/16/12 04:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put muffler seal on any possible leak points...
I prefer to run a left and right bung... check both
sides and see if you have a lean and rich side and if
you do try a stagger jetting but if they are close
then dont worry about which side... just mount it so
its easy to get at... make sure its above 3 o'clock
and 9 o'clock so moisture can drain out... once you
get a reading on both sides you can chip off the muff
sealer if you want then get another set of readings
with the so called leaks and use that as the base line
with the difference from the sealed readings... I
dont like putting it in the X due to it seeing a pulse
and not straight flow(straight flow gives you a better
and faster reading)
Re: Innovate wideband o2 [Re: MR_P_BODY] #1286442
08/16/12 04:36 PM
08/16/12 04:36 PM
PA
PA
very good advice...as you always provide!....
Thanks!
Re: Innovate wideband o2 [Re: bwhackd34] #1286443
08/16/12 09:04 PM
08/16/12 09:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i have one,put the bung up high as u can in the middle of the x gasses are on the higher side of the exhaust,from what i was told.It works good.
Re: Innovate wideband o2 [Re: fishy340] #1286444
08/16/12 09:39 PM
08/16/12 09:39 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I have an Innovate 02,AFTER I put it in the X-pipe Innovate told me not the best idea,
A bung in each heaader and move it side to side is more accurate.
It does work in the X-pipe,they just told me theres better locations
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Innovate wideband o2 [Re: MR_P_BODY] #1286445
08/17/12 02:18 PM
08/17/12 02:18 PM
PA
PA
Here's a good question......do evac tubes count as 'leaks'......
Re: Innovate wideband o2 [Re: bwhackd34] #1286446
08/17/12 03:47 PM
08/17/12 03:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You have to make sure the e-vac is down stream of
the O2... if its ahead of the O2 it will get a bogus
reading sensing the oil and air
Re: Innovate wideband o2 [Re: MR_P_BODY] #1286447
08/17/12 07:49 PM
08/17/12 07:49 PM
PA
PA
Thanks again!
