wiper motor question?? #1282183
08/09/12 08:42 PM
08/09/12 08:42 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
two speed wiper motor in ebody. car sat for twenty five years, recently restored, with the exception of the wiper motor. Motor works, but wipers are very slow, only work in one speed and will not fully go back into park> Is it a motor problem? Switch? Ground? ballast resister thing??
Re: wiper motor question?? [Re: sailboat] #1282184
08/09/12 09:38 PM
08/09/12 09:38 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i would say after all those years of sitting it's a combination of all except the ballast. re-ground, take switch apart and clean, try again!
Re: wiper motor question?? [Re: mikemee1331] #1282185
08/09/12 09:39 PM
08/09/12 09:39 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
you think more the switch than motor?.
Re: wiper motor question?? [Re: sailboat] #1282186
08/09/12 10:11 PM
08/09/12 10:11 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
after 25 years it could be anything or a combo of all. if it were me i would start by re-grounding the motor and then switch. those are just the easiest and most likely places to start.
Re: wiper motor question?? [Re: mikemee1331] #1282187
08/10/12 10:55 AM
08/10/12 10:55 AM
WV
JohnH Offline
JohnH  Offline
WV
Peplace the motor,, switch is working because it is sending power to the motor... I just put one on my Charger,,, NAPA has them..
Re: wiper motor question?? [Re: JohnH] #1282188
08/10/12 05:51 PM
08/10/12 05:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if you have the coin, then by all means replace everything! it's most likely a bad ground.
Re: wiper motor question?? [Re: mikemee1331] #1282189
08/12/12 12:16 PM
08/12/12 12:16 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Thanks guys. Turned out to be a wire broken off in the w/w moor harness. Break wasnt visable as it was in the actual bakelite connector.
