Re: 70 FT. LBS.??? [Re: Labratt] #1281590
08/10/12 02:26 PM
08/10/12 02:26 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I picked up 7/10 from mild port 346 heads with large valves to the MCH port RPM's milled to 76 cc and a torker to a victor manifold.
The shims are the steel .020 head gaskets, i copper coated them.
I reckon even if you get 10.80 that's 4/10 improvement, also it's a bit of extra street cred, when someone asks you how quick it is and you tell them it's a 10 second car.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 70 FT. LBS.??? [Re: Labratt] #1281591
08/10/12 03:19 PM
08/10/12 03:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I got my engine pretty much back together... gotta
put the pan on it with a couple of bolts then try
the oil pressure... if thats fine then I'll put the
intake on and finish it up.... I'll let ya know what
day the dyno will run... Dale wants to come watch also
Re: 70 FT. LBS.??? [Re: MR_P_BODY] #1281592
08/10/12 05:43 PM
08/10/12 05:43 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Good luck with the engine Mike
best 60ft 1.36
Re: 70 FT. LBS.??? [Re: deaks] #1281593
08/10/12 07:35 PM
08/10/12 07:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks... I'll find out tomorrow if what I did this
time is going to work and make it worth while... all
I need to do is put the pan on and prime it to find
out... I know the rings will work but I also had a
low oil pressure issue which I believe was sloppy
lifter bushings... I'll see
Re: 70 FT. LBS.??? [Re: MR_P_BODY] #1281594
08/11/12 01:42 AM
08/11/12 01:42 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Mick! I'd be VERY HAPPY with 10.80's! Sounds like you're happy with Jeff's work! Mike...let us know how the oil pressure turns out.... I'm sure it'll be fine! Can't wait to see the dyno numbers next week! .....REAL curious to see just how "friendly" St. Clair's dyno is.
Re: 70 FT. LBS.??? [Re: Labratt] #1281595
08/11/12 02:03 AM
08/11/12 02:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think I'm gonna take my gas 1050 dom and my adapter
to see what the difference is over the 850... I'm
curious to see if its friendly or not... doesnt matter
to me much... Sean thinks it should exceed my wants
but we'll see
Re: 70 FT. LBS.??? [Re: MR_P_BODY] #1281596
08/11/12 09:44 AM
08/11/12 09:44 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Randy, What did the machine shop use for a head gasket, fasteners, fastener lube and torque values when the block was honed with a plate?
Any deviation from these values can cause cylinder bore distortion in my view.
If the shop used the same head gasket, torqued the same fasteners to 70# with 30 weight oil and honed......
Then you torque the heads to 75# with ARP lube..... I'd be getting my dial bore out to check the cylinder especially on a stock block.
JMO
Re: 70 FT. LBS.??? [Re: roadhazard] #1281597
08/11/12 12:32 PM
08/11/12 12:32 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Greg...not sure! Sounds like I need to contact Sean(St. Clair Engine) to get those answers! He's the same guy working with Raff on his Rampage engine build. Thanks for your input,buddy!
