Re: WOW I weigh that much?
[Re: DANA60]
#1279133
08/04/12 02:30 PM
08/04/12 02:30 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Sounds right, when I weighed my 73 charger bb before I put it on a diet, with me it was 4250#!!!!!!
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#1279137
08/04/12 03:20 PM
08/04/12 03:20 PM
Posts: 27,444 So Cal
autoxcuda
So Cal
What does it weigh after the diet?
What was the diet?
[Re: rth]
#1279140
08/04/12 11:54 PM
08/04/12 11:54 PM
Posts: 616 TP Exit 7, NJ, USA
DANA60
TP Exit 7, NJ, USA
That sounds correct. By the way I was at the old time drags with my R/T (just in show), your car is cool. Nice job.
I saw your car and took a look at it (you were not around), loved it! Where in Jersey are you from?
[Re: Mr.Yuck]
#1279141
08/05/12 12:03 AM
08/05/12 12:03 AM
DANA60
TP Exit 7, NJ, USA
most important is what times did you turn. Next time drop and jack the spare, use only 1/2 tank and remove anything else that isn't bolted down.
Had not raced in 31 years (yikes), did some time trials the week or so before, got the car in low 11's. I know it will do better if I can get some traction. This Nostalgia Show was the best time (no new stuff allowed). I'll run again at the Mopars at Englishtown.
[Re: DaytonaTurbo]
#1279143
08/05/12 11:27 AM
08/05/12 11:27 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Hey Ron, I was always curious, did you ever weigh your 63?
Yes I have as with me in it and the rollbar it was a tad over 3700 lbs.
Dana60 what is your combo if you dont mind me asking ? Low 11's is plenty strong for a street car. Ron
[Re: kilroy]
#1279145
08/05/12 04:26 PM
08/05/12 04:26 PM
DANA60
TP Exit 7, NJ, USA
HEMI Callis bottom, Ross 10.5 60 over 3/4 stroked=525 CI Stage V heads Engle K-8 586 lift int, 249@.5 Dur Marine Intake duel 750 Holly, TTI 2.125 TTI, 3 inch exhaust althoug I use QTP electric cutouts (open). MSD 6al Mopar Elec dist. Lupo TC, his shop did the 727, just beefed no manual reverse. Strange 60 410. 305-45-18 Nittos 555 rear, although I have the Nt-05's to use next time, Cal traks(horrible on the street, noisy!)
[Re: DANA60]
#1279147
08/05/12 06:23 PM
08/05/12 06:23 PM
Posts: 4,309 Prospect, PA
BSB67
Prospect, PA
Nice. What mph and 60 ft? Do you have a roll bar?
[Re: DANA60]
#1279149
08/05/12 09:32 PM
08/05/12 09:32 PM
BSB67
Prospect, PA
No roll bar. At ATCO they didn't seem to care at Englishtown they didn't say anything because we were in the elimination rounds I was running 11.5 for my time trials and got lower as the day went on, but my 60 was still at 1.7. Maybe some of the Jersey NY and PA people can chime in. Is ATCO a faster track then ETown? My 60 at the few time runs I made at ATCO were in the 1.6 range around 1.7 at Englishtown. I guess my weight made my ETs better then my 60 looked. MPH ranged from 118.5 to 121.5 at both places. Keep in mind, many of my runs were with little, to some, to extreme tire spin. 5800 shifts and around 6000 RPM going through the traps.
Some tracks watch this closer than others.
I have not run at either track. Everything else equal, Atco might be faster as it is at a little lower elevation, but not much. Track prep, and the weather conditions of the day would make a bigger difference than elevation between these two.
Tire spin has a much greater effect on et than on mph. My et is a littler slower than yours, but my 60' is about 1.9. A 1.6 sixty ft. and fall Atco air and you should be dancing with 10.90s IMO.
