Re: '73 Fury upgrade - asking for help and recommendations
[Re: dogdays]
#1278973
10/16/12 01:30 PM
10/16/12 01:30 PM
HemiFury1973
Where are you located? I reread the entire thread and have a feeling that you're not in the USA, making parts a little harder to find. R.
I am located in Israel :-)
[Re: RapidRobert]
#1278974
10/16/12 01:32 PM
10/16/12 01:32 PM
HemiFury1973
and a new mopar performance ignition kit
If it comes with an orange box I would suggest keeping a spare 4 pin ECU in the glove box. Your parts house has em for cheap. I'm assuming you already have electronic ign. I'd get a hotter coil/ballast. I use a FBO coil and MP 1/4 ohm ballast and OE ECU & it starts/runs awesome. the power is pretty much from the coil/ballast combo & not the coil primary switcher (ECU) but people are raving about FBO's new ECU. EDIT If needed there is a pentastar ECU harness/pigtail assy for $28 in the BB for sale section page 6 which may or may not come with the 2 terminal nominal 1.25 ohm ballast but was not shown in the pic
This is the set i bought. It comes with a new resistor.
http://www.summitracing.com/parts/DCC-3690427
What is ECU?
[Re: HemiFury1973]
#1278975
10/16/12 07:51 PM
10/16/12 07:51 PM
RapidRobert
What is ECU?
Electronic Control Unit, the orange box in the pic. EDIT you'll have the 1.25 ohm resistor in that kit. I'm assuming you have an OE 5 pin ECU and 4 terminal (dual) ballast. You can pull the dual OE ballast & plug in your new ballast to the 2 connectors that were on the lower ohm side of the "dual" ballast. This's let you use your wiring unaltered if desired & if the orange box fails you can easily plug the 5 pin ECU/4 terminal dual ballast back in.
[Re: RapidRobert]
#1278976
12/29/12 01:15 PM
12/29/12 01:15 PM
HemiFury1973
What is ECU?
Thank you so much. Yesterday the new set was installed. The guy who did the work said there is no need to replace the resistor and the old one was not replaced. Is it true or should i replace the resistor as well? I feel a slight difference in the ignition and throttle response now.
Thanks,
Hemi
[Re: RapidRobert]
#1278978
12/29/12 05:53 PM
12/29/12 05:53 PM
Posts: 15,806 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
If it were mine; i think I would find a cheap used stock Mopar iron 4 barrel intake, or if not then a performer intake, and swap it along with a thermoquad carb, and dual exhausts. Relatively easy changes to make without trying to get too much out of a smog engine. Those should make a nice difference. Then maybe eventually 3.23 gears to liven it up even more
Btw, beautiful car!
Facts are stubborn things.
[Re: larrymopar360]
#1278980
12/29/12 08:41 PM
12/29/12 08:41 PM
Posts: 6,558 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Btw, beautiful car!
I'm assuming the supply of used american car parts in Israel is sketchy at best but a stock iron intake with a Thermoquad and a set of 2.5" duals with an H-pipe and good mufflers will wake it right up.
Another cheap but somewhat time consuming mod would be to get a roller 9 way key timing chain set, a degree wheel kit and advance the cam that is in it 4 degrees. That will increase bottom end torque and with the actual compression ratio being in the 7's:1 range, (the manual lied lol) you can use all the help you can get.
Oh by the way, nice car.
Kevin
[Re: HemiFury1973]
#1278981
12/30/12 04:30 AM
12/30/12 04:30 AM
Posts: 953 Chicago
PurpleBeeper
Chicago
Wow that car is beautiful! My first car was a 73 Fury III two door 360 2bbl. Since you already have the carb & intake I suggest a true dual exhaust and rear end gears. Assuming it is an 8-3/4" then you could run 3.23, 3.55 or higher. It all depends on what you want to do with the car and how much money you have for expensive Israeli gasoline. 3.23's are probably a good choice and easier to find + don't forget to change your speedometer gear. You might also consider a K&N air filter in any cheap air cleaner you can find (open of course). You don't have to replace the ballast resistor, just keep an extra one in your car. If it won't start all of a sudden, that's most likely the problem (they burn out a lot)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
