650? Holley #1263475
07/07/12 02:06 PM
07/07/12 02:06 PM
GoDartGo Offline OP
GoDartGo  Offline OP
picked up a free holley that came out of a Mopar from
the late '70's I believe, because there are four total vacuum
ports on the base plate. The primaries are smaller than
the secondaries.
4367 is the number on the choke horn.
Also the base plate has a fracture that goes through one of
the secondary holes/screw hole and out to the side.
Is this worth rebuilding?
Re: 650? Holley [Re: GoDartGo] #1263476
07/07/12 04:37 PM
07/07/12 04:37 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Re: 650? Holley [Re: Fat_Mike] #1263477
07/07/12 07:30 PM
07/07/12 07:30 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Thanks Mike, good links there
Re: 650? Holley [Re: GoDartGo] #1263478
07/10/12 05:59 PM
07/10/12 05:59 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Okay, what rebuild kit will work with the 4736 Holley?
And where would I get it?
Re: 650? Holley [Re: GoDartGo] #1263479
07/10/12 06:40 PM
07/10/12 06:40 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Air grabber carb eh?.. AED 41601 carb rebuild Kit Holley 4160 Vac.Sec. something around $50 iirc.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 650? Holley [Re: DARTH V8Я] #1263480
07/10/12 07:23 PM
07/10/12 07:23 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Ice-Eagle, you RULE!!!!!! Thanks
