Page 13 of 25 1 2 11 12 13 14 15 24 25
Re: new Moparts fastest car list, post yours! [Re: Glen440] #12874
06/11/05 03:32 PM
06/11/05 03:32 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
-6 second Zone --
6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi
--7 second zone ---
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster.
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
---8 second zone ---
8.02 @ 174+, The Haze, twin turbo 452",
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda
8.17 @ 163, 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---9 second zone ---
9.063 @ 146.23, Beeracuda, 74 Barracuda, 2800#, 499/PG
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
9.14 147mph, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs.
9.172 @ 146.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy,
9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.47 @ 142.5, MR P BODY, 395 ci W-2 2430#
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear
9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR
9.79 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings!
9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 135 398-W2 Duster398
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol
9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid
9.91 @ 142 mph,440 906 heads, Mrsixpak
9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.972 @ 131.56, 1.350 60', Sleepyhead416
---10 second zone---
10.03 @ 135 through exhaust
on dot tires paul swigart 69 pro street cuda
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.09 @131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads
10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A.
10:14@129.70 70 Challenger 040 over 440 eddie heads .footbrake.
10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035#
10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380#
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400#
10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.65 @ 123.43 1.45 60ft 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 11secdart
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 127.38, eeka440 73 Swinger 446 906's auto
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
10.70 @ 125 60' 1.50 3700 race weight 10secGTX
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
10.98 @ 122.29, 1.55 60' Bubba, '80 Mirada, 440, 3855#
---11 second zone ---
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675#
11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned
11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver
11.50 @ 115 1.55 60' 68DART360 ,904, 3200 lbs,eheads, pump gas,full exhaust, 10" tire SS springs
11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane.
11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.74 @ 113.81, 1.55 60', 6PKBEE,77 Aspen R/T 360/904/4.10 @ 3420#
11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750#
11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660#
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car
11.877 @ 112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91
11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
---12 second zone ---
12.02 @ 110, 1.58 60', cudadan
12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
12.393 @ 108.432, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
12:91 @ 102, 1.72 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 100 Top Gun shot, 3250#
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: new Moparts fastest car list, post yours! [Re: 77DragracerR/T] #12875
06/13/05 12:23 AM
06/13/05 12:23 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
6 second Zone --
--7 second zone ---
12.095 @ 113.841, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3950# w/ me
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12876
06/13/05 10:48 PM
06/13/05 10:48 PM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
4th pass on new motor, 499" RB, unported SR heads, 3200lbs, 10.076 131.84 Hazy Hot & Humid day
Re: new Moparts fastest car list, post yours! [Re: 67Charger] #12877
06/19/05 02:16 AM
06/19/05 02:16 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
6 second Zone --
--7 second zone ---
11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane
Re: new Moparts fastest car list, post yours! [Re: SCATPK] #12878
06/19/05 03:33 AM
06/19/05 03:33 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
6 second Zone --
--7 second zone ---
11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me
Re: new Moparts fastest car list, post yours! [Re: 67Charger] #12879
06/20/05 01:48 AM
06/20/05 01:48 AM
Seaside,Ca.
TC67CUDA Offline
TC67CUDA  Offline
Seaside,Ca.
6 second Zone --
--7 second zone ---
10.58 @ 127, 1.51 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's
Re: new Moparts fastest car list, post yours! [Re: TC67CUDA] #12880
06/20/05 11:16 AM
06/20/05 11:16 AM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
6 second Zone --
--7 second zone ---
7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: new Moparts fastest car list, post yours! [Re: Slingshot383] #12881
06/20/05 04:10 PM
06/20/05 04:10 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
6 second Zone --
--7 second zone ---
9.100 @ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12882
06/20/05 05:55 PM
06/20/05 05:55 PM
1970 dart. 3000 lbs w/o me. NO-Transbrake.
10.19 @ 129.63 1.395 60 ft.
Re: new Moparts fastest car list, post yours! #12883
06/23/05 04:03 PM
06/23/05 04:03 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
6 second Zone --
--7 second zone ---
12:64 @ 104, 1.72 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#
Re: new Moparts fastest car list, post yours! [Re: slantzilla] #12884
06/23/05 04:39 PM
06/23/05 04:39 PM
Kauai, Hawaii
452RT Offline
452RT  Offline
Kauai, Hawaii
6 second Zone --
--7 second zone ---
11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver
Re: new Moparts fastest car list, post yours! [Re: 452RT] #12885
06/24/05 11:36 PM
06/24/05 11:36 PM
NY
B1duster Offline
B1duster  Offline
NY
8.94 at 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s
Re: new Moparts fastest car list, post yours! [Re: 452RT] #12886
06/25/05 03:10 AM
06/25/05 03:10 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
---6 second Zone ---
---7 second Zone ---
---8 second Zone ---
---9 second Zone ---
---10 second Zone ---
10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake.
---11 second Zone ---
---12 second Zone ---
Re: new Moparts fastest car list, post yours! [Re: RT540] #12887
07/03/05 04:08 PM
07/03/05 04:08 PM
Idaho
Runner Offline
Runner  Offline
Idaho
11.80 @ 113.45, Runner 1.645 60' 452ci stock heads xe282s comp solid. 71 roadrunner 3750 lb w/d
Re: new Moparts fastest car list, post yours! [Re: Runner] #12888
07/04/05 06:09 PM
07/04/05 06:09 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
10.02 @ 133, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads, no power adder, 3,035#
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12889
07/10/05 01:51 AM
07/10/05 01:51 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
NEW BEST WITH HE LITLE 318 10.96 @ 120
combination is simple and old school
69 dart 2970 lbs with driver
904 2.45 frst gear T/A 4400 converter
ss springs 28x9 M/T slick 4.10 gear
318 + .030 kb flat tops 0 deck
eagle SIR rods stock crank
mp .557 cam
pocket ported W-2 heads 52 cc 1.6 rocker
victor jr intake jnky home built 750 alcohol carb
1-3/4 x 1-7/8 stepted headder 3-1/2 collector
Re: new Moparts fastest car list, post yours! [Re: W2DODGE] #12890
07/10/05 09:24 PM
07/10/05 09:24 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
http://www.reillymotorsports.com/galleryusers/blownzoom440/Picture_029.jpg
let me introduce myself as blownzoom440.
my car is a 69 sport satellite i have had for 15yrs.starting with a 318 i made my way to its current condition.i assemble,tune my own stuff and race monthly.
my best et was yesterday at dragway 42.
10.72 @126
1.52 60'
6.83 1/8 @100.2 mph.
my motor has wiseco .030 9/1cr,eagle h beam rods,ported iron 346 heads w/o-ring,comp cams .550int,.565exh 113lobe sep,230 dur.
the blower is a BDS 8-71 stage 2,5% overdriven 8 lbs of boost,2 x 850 holleys,3.73 dana,28" tires.
my build is like this article
http://moparmusclemagazine.com/techarticles/155_0408_dyno/index.html
but with a 440,iron heads.
Re: new Moparts fastest car list, post yours! [Re: ProSport] #12891
07/17/05 08:43 PM
07/17/05 08:43 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
11.884 @ 113.07 1.66 60', BBLM23, 69 Dart, 3340lbs w/driver. Street tires, mufflers, 93 octane.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: new Moparts fastest car list, post yours! [Re: RT540] #12892
07/28/05 09:06 AM
07/28/05 09:06 AM
orange city,FL
Demon340GSS Offline
Demon340GSS  Offline
orange city,FL
8.01@ 174.89MPH, spinning 1.06 60Ft,2460 lbs,@ Orlando, Fl Grant Eatons Demon540,10-71BDS, 4link,Backhalved.(it's a real licenced street driven car folks!!!!!)
Owner of Original collector and restored original mopars from Mr Norms Grand Spaulding Dodge.
Re: new Moparts fastest car list, post yours! [Re: topfueldart] #12893
07/28/05 10:48 PM
07/28/05 10:48 PM
65 Dart, 422" R-3 bullet, 904 trans, 750 carb, dana 4.56, 12.25:1 squeeze, roller cam, aluminum heads, hogans intake, home made headers. 1.36-60' [Email]10.19@128.[/Email]
