What's Missing? #1258055
06/26/12 11:19 PM
06/26/12 11:19 PM
Iowa
Hey19 Offline OP
Hey19  Offline OP
Iowa
I have a car that I race that has a 408, eddy heads, headers with stock electronic ignition with chrome box. I have a 780 double pumper with 3/8 line and a holley electric fuel pump on the stock tank. I run 1/8th mile, in the 7.1 at 96 area. Occasionally it will miss slightly (2 to 4 times) on the top end and loose 1 or 2 mph. The very next pass it will run good through the whole 1/8th mile. The last time it missed at the end when I let off of it it back fired as it coasted down the lane (if that is a clue to anything). Does anyone have a guess or a way to determine if my problem is gas or electrical? I am considering putting an MSD system on it but I would really hate to waste $500 and still have the miss.Any ideas? Thanks
Re: What's Missing? [Re: Hey19] #1258056
06/27/12 12:05 AM
06/27/12 12:05 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
We used to have several people here more than willing to give advice but, it seems lately it turns into a fight
I myself have had little to no luck with the Mopar ignition stuff , its all built out of the USA and quality has been lousy
I'd for no other reason replace that even its not the problem
Good luck with the hooptie man, some times those crazy skips are hard to find
ps
Post pics of it , we like pictures !
Re: What's Missing? [Re: bigdad] #1258057
06/27/12 12:25 AM
06/27/12 12:25 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
My first though would be the ignition is not up to the task. Get a 6AL and a new coil.
Alan Jones
Re: What's Missing? [Re: Hey19] #1258058
06/27/12 12:28 AM
06/27/12 12:28 AM
The first thing I would do is check all the grounds on the ECU and all the motor ground straps and clean them very thoroughly
Re: What's Missing? [Re: Cab_Burge] #1258059
06/27/12 12:32 AM
06/27/12 12:32 AM
6AL all the way.
Check the reluctor gap in the distributor before you do anything, though...
Re: What's Missing? [Re: bigdad] #1258060
06/27/12 12:40 AM
06/27/12 12:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They aren't the only one outsourcing to increase the bottom line ...
good luck
Re: What's Missing? [Re: JohnRR] #1258061
06/27/12 12:47 AM
06/27/12 12:47 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
good luck
Quoted for truth ..
I for one would rather pay for quality and they can increase it that way .
Buying junk decreases my bottom line
Re: What's Missing? [Re: bigdad] #1258062
06/27/12 12:52 AM
06/27/12 12:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
BD , cool shirts
Re: What's Missing? [Re: JohnRR] #1258063
06/27/12 12:55 AM
06/27/12 12:55 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Thank you
