Re: 4 Speed?
[Re: Z_Z]
#1257890
06/26/12 07:31 PM
06/26/12 07:31 PM
Posts: 1,505 TN
SCATPACK 1
TN
Bumer, that happened to a car I had back in the 70's. You may need to put a limiter on the passenger side of the engine that will tie the engine to the K-frame. This limiter goes from the front of the K-frame to the side of the block near the motor mount or pan rail and prevents the engine from twisting sideways/clockwise if you were looking at it from above. We kept having issues with trans mounts breaking and this fixed our problem. We had solid Sox Martin style mounts and it still twisted without the limiter on there.
Old Geezer Racing
Re: 4 Speed?
[Re: SCATPACK 1]
#1257891
06/26/12 10:05 PM
06/26/12 10:05 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Uh, the limiter should go on the drivers side. Which is the left side of the car.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: 4 Speed?
[Re: Z_Z]
#1257893
06/26/12 10:45 PM
06/26/12 10:45 PM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
I do have a schumacher torque strap on the car.
it broke because of the bent output , change the output and tail housing and check your driveshaft and pinion angle .
Re: 4 Speed?
[Re: Z_Z]
#1257895
06/27/12 12:37 AM
06/27/12 12:37 AM
Posts: 43,096 Bend,OR USA
Cab_Burge
I wouldn't be suprised that the tail shaft and main case is cast steel, not cast grey iron If so you can have it welded You need to make sure that the drivshaft doesn't bottom out, slide the trans yoke in all the way and then slide it out 1 to 1 1/2 inches, that should be the center of U joint to center of U joint length needed to avoid future problems, make sure the car is sitting with the suspension loaded, not hanging down off of jackkstands under the sub frames
