18" steel wheels #125775
09/24/08 06:03 PM
09/24/08 06:03 PM
Northport, al.
tvt59 Offline OP
tvt59  Offline OP
Northport, al.
Does anyone know who can make an 18" steel wheel that the dog dish hub caps will fit?
Re: 18" steel wheels [Re: tvt59] #125776
09/24/08 07:25 PM
09/24/08 07:25 PM
E
earlymopar Offline
earlymopar  Offline
E
I'm not certain who does but you might contact any of the following via the web:
- Wheel Smith
- Pete Paulson
- Sacramento Wheel
- Wheel Vintiques
Its really a matter of using the correct steel wheel center from the wheel that fits with the dog-dish hubcap and putting it into the wheel outer you want to use. The question is, does anyone make an 18" OEM steel wheel"? I'm not sure myself.
- EM
Re: 18" steel wheels [Re: tvt59] #125777
09/24/08 07:33 PM
09/24/08 07:33 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I have 17" steel wheels from a Magnum on my 36 Plymouth and my 36 hubcaps fit the centers great. I had to make the spring clips.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: 18" steel wheels [Re: 36PLYM] #125778
09/25/08 10:39 PM
09/25/08 10:39 PM
Northport, al.
tvt59 Offline OP
tvt59  Offline OP
Northport, al.
Toyota Tundra had some 18" Dia. factory steel wheels.
Re: 18" steel wheels [Re: 36PLYM] #125779
09/26/08 10:23 AM
09/26/08 10:23 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
17" Steel wheels from a new magnum or an old magnum?
Re: 18" steel wheels [Re: bohmer2] #125780
09/27/08 09:23 AM
09/27/08 09:23 AM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
17" wheels from a new Magnum, these also came on some 300's and the new Charger. They have 4 1/2 inch bolt patterns, check the center opening. Good luck!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: 18" steel wheels [Re: 36PLYM] #125781
09/28/08 07:00 AM
09/28/08 07:00 AM
Saskatoon Saskatchewan Canada
mycreation68 Offline
They don't have a 5 on 4 1/2 inch pattern! They are a metric pattern and are off by about .060" on an inch. They are a 5 on 115mm pattern. the 5 on 4 1/2 pattern translates to 5 on 114.3mm now minor you ask? well that .7 of a mm could lead to stress cracking as your only grabbing on I believe only 20% of the hole. Now dangerous maybe not right now but a year or two down the road the wheels may break and cause extreme amounts of damage.
Re: 18" steel wheels [Re: mycreation68] #125782
09/28/08 07:26 PM
09/28/08 07:26 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I have checked into this before I assumed these wheels would fit. The difference in 4.5 inches and 115mm(4.52755") is the .02755". When split in half the difference in the centers of the stud and the hole is only .013755", which is less than 1/64 of an inch. The combined tolerances of the stud, nut and wheel are well within this limit. After forty years of engineering, machinist, welding and building cars I am sure that this is a correct swap. Also Hollander list the 5x4.5, the 5x114.3 and the 5x115 as interchangeable.
