Console installation - Cut the carpet or not? #1255070
06/21/12 03:15 PM
06/21/12 03:15 PM
State, country, etc.
gss Offline OP
gss  Offline OP
Does the carpet in a Challenger need to be cut to reveal the console brackets or are the screws just driven through the carpet?
If it needs to be cut, where is the proper place to cut it?
Do the screws just screw into the slots in the brackets or is there a sheet metal nut?
Thanks!
Re: Console installation - Cut the carpet or not? [Re: gss] #1255071
06/21/12 04:46 PM
06/21/12 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Disclaimer ... I don't know how the E body carpet is exactly cut ...
Carpet is cut so the brackets are exposed , you can cut it as you see fit as long as you keep it as one piece , the screws just go into the slots , no nut plates of any kind.
Re: Console installation - Cut the carpet or not? [Re: gss] #1255072
06/21/12 04:55 PM
06/21/12 04:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
the carpet is sliced to expose the console brackets, you want to mount the console securely on top of the brackets, no carpet between the console and bracket(s) the screws cut their own thread
Re: Console installation - Cut the carpet or not? [Re: DAYCLONA] #1255073
06/21/12 05:03 PM
06/21/12 05:03 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Is this an auto or manual? It's easy to cut the carpet too low. If you have to cut around the auto shift linkage be very careful. I ended up tracing the outline of the console with painters tape so I wouldn't slice down too far.
Re: Console installation - Cut the carpet or not? [Re: burdar] #1255074
06/21/12 06:06 PM
06/21/12 06:06 PM
gss Offline OP
gss  Offline OP
It is a 4 speed. And yes my concern is cutting too low. I just want to do something that at least remotely resembles the factory installation.
Re: Console installation - Cut the carpet or not? [Re: gss] #1255075
06/23/12 04:27 PM
06/23/12 04:27 PM
NC
1970A66 Offline
1970A66  Offline
NC
On my 70 Challenger 4-speed car I cut around the console brackets so the carpet will lay flat on the floor hump. The carpet is cut tight to the brackets.
The screws thread into the slits.
Re: Console installation - Cut the carpet or not? [Re: 1970A66] #1255076
06/26/12 01:13 AM
06/26/12 01:13 AM
gss Offline OP
gss  Offline OP
Thanks for the replies!
Can anyone tell me exactly what fasteners are used to screw into the brackets? How about the shift boot trim ring?
