71 Charger Hideaway Grille Swap to Standard Grille
#1254423
06/20/12 05:10 PM
06/20/12 05:10 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
I want to rid my 71 Charger 500 of the hideaway headlights and go back to the standard grille. To change to the standard grille, is it a simple swap or are there complications and differences? Brackets required? What will I run into? Thanks for inputs!
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 71 Charger Hideaway Grille Swap to Standard Grille
[Re: T2R9]
#1254425
06/20/12 08:21 PM
06/20/12 08:21 PM
Posts: 21,637 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Its a pretty straight forward swap. You will need the three U shaped standard grill brackets for each side. The attachment hardware is the same as the small hideaway brackets. The top support is the same. If you want to remove the remote hood release you will also need a manual one and the release lever.
yup, pretty straight forward conversion, may even make your frontend ligher. Save that SE grill as they are hard to find and very pricy.
