Fluid Dampers #124790
09/22/08 07:54 PM
09/22/08 07:54 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Has anyone tried one before and after installation? I understand they somewhat correct torsional vibrations. I have slight vibrations in the engine (340 auto)at a couple different rpm. Do these dampers work on these? Also are fluid dampers other than Fluidampr(c)any good?
Re: Fluid Dampers [Re: JonC] #124791
09/22/08 11:29 PM
09/22/08 11:29 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
BTT
Re: Fluid Dampers [Re: JonC] #124792
09/23/08 12:23 AM
09/23/08 12:23 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I dont think Fluidamper has anything over the other fluid type dampers except another hundred bucks. They do better that the elastomeric dampers and are a captive fit so they wont tear off and go spinning out the side of your car. TCI makes a mechanical damper called the rattler. These 2 piece dampers have less rotational weight and look alot better than the iron ones. The CAT dampers and other branded dampers are almost cheaper than the correct rebuilt iron ones. Be careful if you get one for a B/RB as the flat faced ones will misalign your pulleys, look for the recessed front ones. They were a second generation design, and most dont include the bolt which I found needed to be about 1/4 inch longer as they are thicker down there.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Fluid Dampers [Re: JonC] #124793
09/23/08 01:19 AM
09/23/08 01:19 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
for the price of a Fluidamper you can get an ATI Super Damper
last damper you will ever need
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
