Re: Why do some need help finding the staging beams??
[Re: mcat4321]
#1243093
06/01/12 05:58 PM
06/01/12 05:58 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
i help with a unlimited 8.5 car. the tire size is 9 inches wide, it goes low 1.2x sixty foot. it runs low 5's in 1/8. it take a certain mind set to do that. in the time after the burn out, the driver needs to check all gauges, turn on nitrous, open bottle , find the best part of the track as possible , pre stage bump im... all while worrying about how the car is going to react... will it hook and go, will it blow the tires off? will it stand straight up?, all of which he has to deal with differently... so if anything having your buddy put you in the beams is just a little comforting. having him put you in the best groove is that much more comforting. and knowing he is making sure your perfectly straight, so you dont mow the tree if it wheels stands helps too. its a lot mental
Not saying this doesnt help, But I also have a good friend runs real street with a 4000 lb chevelle on small radials, turbo car runs low 8's at high 160's and I have never seen him get any help. Just saying!
67' charger 499 RB
10.57 at 127
[Re: mcat4321]
#1243094
06/01/12 09:22 PM
06/01/12 09:22 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Well I drive a low 11 sec street car, and when I'm at the track I have to worry/think about all of those things too. Well except for nitrous or standing up straight.
The turbo car reason is the best I've heard so far.
codfish
[Re: MRMOPAR622]
#1243095
06/01/12 11:46 PM
06/01/12 11:46 PM
Posts: 288 no mans land
racerbychoice
no mans land
The Rules at most tracks say you can have 1 helper so why not use them.That's an extra set of eyes to help check every thing like oil or lose parts left over by other cars. Unlike a lot of people I can load my race-car in the trailer unload it and race it at the track all by myself I need no help what so ever,but it makes everything so much easier when you have good help.At the present I have 2 of the Best that I have ever had in my 25+ years racing,so yes they are going to be out there with the car every time. If you want to Win races you have got to be on top of everything that is going on,and 1 person just can not do that.
BINGO! Smart racers do just that. Doesn't matter if its a 16-sec car or 6-sec car in the 1/4, its all about having at least a 2nd set of eyes on the car, and the track so that you or the car can live to make another pass.
Every one of you guys who are saying its not needed know that if you pull up to the line, launch and put your car into the wall or close enough to doing it (because of some mechanical failure or fluid loss) you know you'll have someone out there the next time. Maybe not to put you in the beams, but to give things a 2nd look before you launch.
[Re: MR_P_BODY]
#1243098
06/02/12 01:36 AM
06/02/12 01:36 AM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
When i run left sometimes i have someone help me. My scoop is so big an my helment can only go to right right so far becouse it hits halo. I dont do it all the time but its handy. It attracts alot of attention an sometimes i really dont want that.
Shawn Jennings
[Re: 572_dup2]
#1243099
06/02/12 01:53 AM
06/02/12 01:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
GOOD GOD... how do you get in your car with the side bars bent up like that... I would have run them straight or bent down
[Re: Leon441]
#1243101
06/02/12 08:48 AM
06/02/12 08:48 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
If a racer needs 10 extra set of eyes to cover his incompetence as a driver, I say go for it. But, if one of you A-holes steps in the beams and lights the stage bulbs don't get mad that I turned mine on.
I have a huge boxe of of winners trophys and a couple more of winner ups. And never did I want or need anyone to line me in the groove or help me stage. To me it just seems to be part of driving. In fact if you volunteer and I tell you not to mess with me after the burnout you might end up running for you life when you do it anyway. 23 years racing the same car if I can't find the groove and what part of the groove I desire and stage myself it is time to turn the responsibilities over to someone who can.
There are some cases like a clutch car, boosted car, or a new driver that needs a little help until adjusted with a particular track. Sometimes racing a new track you have trouble getting to the first stage bulb. Maybe a guy who let's you know how close you are to the beam is good. But, more often than not the helpers step in the beams. This should be an immediate disqualification IMO.
Leon
[Re: Leon441]
#1243102
06/02/12 09:06 AM
06/02/12 09:06 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Thought the topic was getting into the beams .I agree with most too many helpers . If you can't get to the prestage then to the stage beams you need another sport . Or get a hood scoop that you can see over ,around. Even a pro car shouldn't get help . Guess a turbo car needs all the help it can get . because its fast.
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: MR_P_BODY]
#1243103
06/02/12 09:48 AM
06/02/12 09:48 AM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I used to think Atco was bad...til I went to Milan last weekend...the entourages are one thing...plus they let spectators stand close enough to the water box you could touch the cars...I've seen street racing that was safer/more organized...haha
Milan never use to be that way... but I havent been to the heads up in 2 years
He's probably talking about the no ET Nationals. It's a different Milan that day.
[Re: dustergirl340]
#1243104
06/02/12 10:50 AM
06/02/12 10:50 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Leon441]
#1243105
06/02/12 10:58 AM
06/02/12 10:58 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Hey 383man from your picture it looks like you are in the far right side of the grove. Just sayin!
Na thats just an illusion. Look at the right rear tire and you can see its right in the middle. Ron
I would agree Ron you are in the groove. The glossy black is the VHT. The flat black stripes in the glossy black are the grove. Appears to me Ron you are in the groove.
Leon
Of course I am groovey I grew up in the 60's and 70's. Ron
[Re: codfish]
#1243106
06/02/12 01:11 PM
06/02/12 01:11 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
codfish
low 11 and low 8's..a little different mind set
[Re: mcat4321]
#1243107
06/02/12 04:01 PM
06/02/12 04:01 PM
Posts: 4,421 in a chair
mopartony
in a chair
Ok I am going to jump in on this.
I agree all the Klinger wanna bes need to go. No need for 10-15 people for one car.
Josh, your turbo example is perfect. The fast cars need it. Less for the driver to worry about. as mentioned above, get all set go through your routine and then roll forever to the prestage, sorry, I think that would mess with 99% of the people here. expecting the light to be a foot or 2 and it is 6 or more.
Now for being a hater on 4-5 guys with a car on the line at test and tune, be it a 8 second car or a 12 second car. The 8 second car, yeah needed, EDIT: Can it be done with less, sure. But if 4-5 guys is a normal race routine, why mess with it. If only 1-2 are normal, great 1-2 on the line is what is needed. It is good practice for the crew too, stayin in the routine. END EDIT 12 second? Maybe, how do you know there is not an issue they are trying to sort and extra eyes will help find it. New build? New car to them? new combo? alot of variables.
So get the Kingers off the track, crew only limit 5.
sorry for the rant.
[Re: mcat4321]
#1243108
06/03/12 12:19 AM
06/03/12 12:19 AM
codfish
Newfoundland
codfish
Naw. Still lookin at and checking same things.
codfish
