Looking for some good advice on an appropriate cam for:
383 stroked to 438 cubes
~10.5:1 compression
Factory manifolds (intake & exhaust)
Factory heads w/fresh valves & 3 angle valve job
Car will be in a 4-speed E-body w/3.55 gears- mostly street use so torque and at least some vacuum for the power brakes is important.
Had a Comp Cams XE262 in the last big-block and felt it was too mild
