Re: head gasket thickness
[Re: jamesc]
#1237850
05/23/12 02:39 AM
05/23/12 02:39 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
why would you want to?
I'm guessing to solve a clearance issue..
[Re: Jeepmon]
#1237851
05/23/12 08:56 AM
05/23/12 08:56 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
I have SCE .096 copper head gaskets on a magnum engine with 5 years of racing on them. I have had the heads off once to rework for larger lift and springs. has never leaked in any way. Iron heads tho.... Iron Ram heads. Reason: machine shop ordered LA pistons for my magnum block. Pistons stuck way out the top of deck and magnum heads are closed chambers.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: hankcrank]
#1237853
05/23/12 02:25 PM
05/23/12 02:25 PM
Posts: 5,875 communist bloc of new jersey
jamesc
that's what i was figuring but depending on exactly what you're doing it's a good idea to keep the quench distance as tight as reasonably possible
[Re: jamesc]
#1237854
05/23/12 03:41 PM
05/23/12 03:41 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I was also looking at maybe someday switching to a really thick head gasket to get the compression down for pump gas. The cometics come up to like .120
67' charger 499 RB
10.57 at 127
