670 holley street avenger #1233500
05/14/12 08:04 PM
05/14/12 08:04 PM
bentman Offline OP
bentman  Offline OP
would a holley 670 work on a 408 stroker keep in mind just a staurday night special
Re: 670 holley street avenger [Re: bentman] #1233501
05/14/12 08:14 PM
05/14/12 08:14 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Could you elaborate more on the engine and what it is going in? To answer you question will a 670 carb work? The answer is yes but may not be optimum. A 750 CFM may run a little better.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 670 holley street avenger [Re: 71yelladustr] #1233502
05/14/12 08:30 PM
05/14/12 08:30 PM
bentman Offline OP
bentman  Offline OP
10 to 1 piston flat top, air gap intake, procomp heads 1.92 valve, 3.55 rearend 2500 stall car is a 73 RR
Re: 670 holley street avenger [Re: bentman] #1233503
05/14/12 10:03 PM
05/14/12 10:03 PM
Missouri U.S.A.
Missouri U.S.A.
What cam? Never the less, Id put a 750 to 770 cfm on it with vac. secondaries and go have some fun.
10.02@134
Re: 670 holley street avenger [Re: 71yelladustr] #1233504
05/18/12 07:12 PM
05/18/12 07:12 PM
dogdays Offline
dogdays  Offline
If you have the 670 run it. If the car is a Saturday Night Special and you want max power I'd go with the 770 Street Avenger or something by Quik Fuel.
R.
