Re: FelPro 8519PT-1 head gasket cooling holes
[Re: allmopar]
#1230647
05/09/12 10:12 PM
05/09/12 10:12 PM
RapidRobert
open them but use a punch rather than a drill. A drill will catch & shred the composite gasket
[Re: Cab_Burge]
#1230650
05/10/12 03:14 AM
05/10/12 03:14 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Unless you have an engineering degree that states you are smarter than the engineers that designed them I wouldnt mess with them.
I am truckless..
[Re: 340SHORTY]
#1230651
05/10/12 09:00 AM
05/10/12 09:00 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I agree leave them alone.Ive run those and the 1009s and also the SB ones.I now have their marine gaskets on my 12.5 440.Never any problems.The set on my kids 413 have been on 12 years.Same thing no problems.Rocky
Chrysler Firepower
[Re: allmopar]
#1230652
05/10/12 01:12 PM
05/10/12 01:12 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
I am getting ready to install the FelPro 8519 head gaskets on my 440 and I noticed they do not have any lower cooling holes. The top set between the bores are only slits. Why are they that way ? I am going to drill 1/4" holes in the 2 lower cooling pass through locations. The steel shim head gaskets I took off had these 2 locations opened up and all 3 upper locations were larger openings.
Do you have a picture of this steel shim gasket? Does it have a part number on it ? I have an original chrysler steel shim gasket with a 18xxxxx part number and it doesn't have the lower holes opened.
Also why are you switching from the steel shim gasket , did you change the heads ? do you need to lower your compression ?
[Re: 340SHORTY]
#1230655
05/10/12 05:24 PM
05/10/12 05:24 PM
RapidRobert
You might read Sanborns cooling info/mods that are in a sticky at the top of the page. www.moparchat.com then click on circle track chat. Alot of info to read thru but he's at the top of his game with cooling/oiling mods and he addresses the block/gasket holes. Alot can be applied to BB's as well.
