Brake drum out of round tolerances? #1228063
05/06/12 07:03 PM
05/06/12 07:03 PM
State, country, etc.
gss Offline OP
gss  Offline OP
Nobody around here turns rotors and drums anymore and my new drums have about .005" runout. What is acceptable?
Most of the ones I use off the shelf are fine, but after measuring a few, I would say none are perfect. The first set I got shook the vehicle when braking. I measured those at .050" out of round.
Do I need to find someone to cut the new ones?
Re: Brake drum out of round tolerances? [Re: gss] #1228064
05/06/12 07:13 PM
05/06/12 07:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried Midas?
Re: Brake drum out of round tolerances? [Re: gss] #1228065
05/06/12 07:28 PM
05/06/12 07:28 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
nobody where you live can do drum brakes?? where is this?
Re: Brake drum out of round tolerances? [Re: mikemee1331] #1228066
05/06/12 07:42 PM
05/06/12 07:42 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Most older independent shops still do it (for cash and cheap).
They won't have specs for the drums of older cars, but can do a clean up cut no problem.
Some of the chains act like you are just a pain if you ain't looking to buy new.
I have mechanical Aptitude.
I can screw up anything.
Re: Brake drum out of round tolerances? [Re: bboogieart] #1228067
05/06/12 09:35 PM
05/06/12 09:35 PM
gss Offline OP
gss  Offline OP
I'm sure somebody can cut rotors here. My question is how far out of round before it affects the braking?
Re: Brake drum out of round tolerances? [Re: gss] #1228068
05/06/12 10:03 PM
05/06/12 10:03 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
well, bell housing runout should be less than .005, so I'd venture to say that if your drums are .005 out of round, that's probably also a safe number.
if it still pulsates, make sure the shoes aren't glazed over creating slick spots
**Photobucket sucks**
