Re: Troubles getting timing set on 360
[Re: RobX4406]
#1227219
05/08/12 07:35 PM
05/08/12 07:35 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
How much fuel pressure do you have going to the carb?
Is it more than 5 psi? If so turn it down to 5 psi. I know the ede instruction say that you can run up to 6.5, yet, I've never had one run happy there.
it's right around 5 to 5.5 psi
[Re: cal_gecko]
#1227224
05/09/12 01:52 PM
05/09/12 01:52 PM
Posts: 3,877 Oregon
hooziewhatsit
I'll have to try that trick on mine Also try rattling the throttle shafts to see if the bores are worn at all. There should be no lateral movement at all. Your intake is a squarebore, and not a spreadbore, correct? If it's spreadbore, you'll need an adapter plate to give it more room to seal.
[Re: hooziewhatsit]
#1227225
05/09/12 02:09 PM
05/09/12 02:09 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Find someone with a KNOWN good carb, ANYTHING, find a holley 600 vac, and take that one you have off and try it.
The regulator you have is a POS if the pressure is creeping. If you set it at one pressure and it goes above that pressure, it's really not doing anything worthwhile! If you could only handle 100 pounds of weight while moving something from one hand to the other. That weight is regulated and the system suddenly decided to send you 150 pounds of items, what's gonna happen? Likely failure...
Timing, balancer, fuel pressure, carb settings, vacuum leaks and who knows what else is a problem you have.
[Re: RobX4406]
#1227228
05/09/12 03:16 PM
05/09/12 03:16 PM
cal_gecko
Sacramento, CA
You still have the PB booster and everything else disconnected from the engine?
At least the person was honest with you and didn't just take your money. I doubt the metering rods will do squat at idle...
Yeah, everything is disconnected and plugged, the only vacuum line hooked up is the one on the back of the carb, which is hooked up to the vacuum gauge.
[Re: cal_gecko]
#1227230
05/09/12 03:24 PM
05/09/12 03:24 PM
Challenger 1
Cincinnati, Ohio
What about the gas that's in the car? How old is it?
He could put points back in the one he's running now, right?
[Re: Challenger 1]
#1227232
05/09/12 03:27 PM
05/09/12 03:27 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
True , I wasn't thinking about that .
[Re: cal_gecko]
#1227233
05/09/12 03:29 PM
05/09/12 03:29 PM
cal_gecko
Sacramento, CA
Seriously, I'm about ready to have it towed somewhere and just pay someone to get the POS running right for me. I'm going after so many different things (timing, ignition, vacuum, carburetor, possible cam problems, possible compression problems)... it's irritating as hell, and I appreciate all the help everyone's trying to give me, but I know there's only so much you guys can do to help me 'remotely'.. and I clearly have no idea WTH I'm doing. I was all excited to get the car painted, but I think I'm just as discouraged now as I was before I had it painted.
