Re: Running hot and running out of ideas 67 Belvedere
[Re: feets]
#1226320
05/05/12 03:28 PM
05/05/12 03:28 PM
Posts: 3,426 Dandridge TN
Dabee
Dandridge TN
He verified that his radiator is doing it's job. There's no need to look at replacing it. He needs to find the source of the heat.
A loose converter dumping trans heat into the radiator or blown head gasket would easily cause that problem.
I wasn’t suggesting he replace his radiator. I know he said he had good a temperature drop cross the radiator. I was just relating a similar experience with my car hoping it would help him out. I also had a 30 degree plus drop across the radiator but it still wouldn’t cool. When I installed the new radiator and electric fan I left everything else the same. I am convinced even though the three core radiators fin design was inferior installing the electric fan is what cured my cooling problem.
[Re: Dabee]
#1226321
05/05/12 06:07 PM
05/05/12 06:07 PM
Posts: 210 mass,usa
sickhemi
mass,usa
did you paint the radiator?
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
[Re: Challenger 1]
#1226323
05/05/12 06:42 PM
05/05/12 06:42 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
Can you turn the clutch fan by hand with the engine hot? There should be ALOT of resistance.
This is a very real possibilty, it happened to me. New fan clutch and it was back to normal.
Good luck with it.
I'm betting it a at least a couple factors, not just one.
I've seen a bad fan clutch cause overheating before too, so that's another possibility. A guy came into my Dad's gas station with a Chrysler that was overheating. The fan was barely turning while the engine was running.
[Re: Belvedere1]
#1226324
05/05/12 06:48 PM
05/05/12 06:48 PM
Posts: 210 mass,usa
sickhemi
mass,usa
do you have headers on the car and are they uncoated. if the car is running lean at idle it the headers will get real hot
[Re: 6PakBee]
#1226330
06/14/12 07:49 AM
06/14/12 07:49 AM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Hi, here is a write-up I did on my 383 cooling issues. You mentioned you are using the 6-vane pump, you might want to get the 8 vane version. The 6-van is used with an A/C car with a smaller pully, which spins the pump harder. The 8-vane pump is used with a slightly larger pulley on a non-A/C car. Which pulleys are you running? You problem to me sounds either coolant flow related or more likely airflow related (especially considering your clutch fan is not doing the job). This thread is now "archive status", which means no pics, which sucks... if you want the pics of the pump I can dig them up. http://www.bigblockdart.com/forum/archive/index.php/t-20229.html
383, Hemi 4-Speed, AlterKtion, D60
