Re: Another dead orange box.
[Re: cuda-sweden]
#1225488
05/04/12 06:04 PM
05/04/12 06:04 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
Now there's an idea! Room for a heat sink that can't be seen as well.
how about using a broken 404 bc box,theres a big heat sink
what is a 404bc box ?
I want to use the cast the stock electronics come in that way you can just plug it right back into the harness .
I need to figure out to melt the potting out of one of these things , I can whip together something over the weekend .
[Re: Wheeler]
#1225492
05/06/12 10:41 PM
05/06/12 10:41 PM
Posts: 5,435 So Cal
Sinitro
So Cal
Just out of curiosity - has anyone tried the Standard LX101 ignition box? I heard/read from several sources that it was one of the best aftermarket ignition boxes you can buy for Mopars.
Don at FBO said the LX101 box was great until Standard products started manufacturing it overseas. Not sure if this is true?
We have had good luck with the LX-101 it holds up pretty well, the LX-101T (cheaper version) is questionable....
Just my $0.02...
[Re: JohnRR]
#1225494
05/21/12 12:02 PM
05/21/12 12:02 PM
JohnRR
U.S.S.A.
I'm toying with sticking one of those inside an orange box so it will plug into the factory harness . easier to just swap that out and it can be bought ANYWHERE.
I finally started this project yeasterday , Meliting the potting out of it is taking longer than I hoped . I just bought a generic replacement from Vatozone and a friend supplied a parts store replacement ECU for the holder.
If this works out I will look into putting an MSD brain in it .
[Re: Pyper70]
#1225496
05/21/12 05:52 PM
05/21/12 05:52 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
The one thing I learned about those boxes is to have them mounted with the factory spacer that came on 75' & later Charger Brougham's. Its a cad plated piece, makes a -|__|- design....if that box overheats, the insides go melty melty...ever had the back of those things (insulation) melt and run down your firewall? Its not a pretty sight. I had a Chrome Box on my Dart for 5 years and nothing went wrong with it, I just wised up and put an MSD before I became a victim of the failure on one of my long trips.
Can somebody post a pic of that mounting bracket??
[Re: JohnRR]
#1225497
10/26/13 04:17 PM
10/26/13 04:17 PM
Posts: 434 sweden
cuda-sweden
sweden
hej,i think it was the first mopar plug in box made by autotronics/msd. gold colored with big cooling fins.then came the 5c 6c 7c boxes,as far as i know
