Page 2 of 3 1 2 3
Re: Dual 2.5" vs Single 3" exhaust [Re: bboogieart] #1223239
04/29/12 07:55 PM
04/29/12 07:55 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
HotRodDave, thanks for the detailed explanation.. awesome
bboogieart, yup.. the plan has changed. I'm going with a 5.3L from a 2010 Chevy Silverado
So theres no way to run a pipe down the drivers side, the spare tire well is in the way, and to even run 2" pipe both down the pass side, up over the axle to the rear bumper w/ 2 mufflers under the floor pan there is just no way without it looking like a total hack job. I think a single 3" is the way to go for my application.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223240
05/01/12 11:58 AM
05/01/12 11:58 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
Check into the Stealth Bomber articles in Mopar Muscle mid 2004. I planned to do the same on my Duster using an x-pipe instead of the Y so I could use an electric cutout on the extra exit but I gor a smokin' deal on a TTI exhaust. Dyno numbers were included. If you are interested I probably still have the mags. IIRC there was only .5" backpressure.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Dual 2.5" vs Single 3" exhaust [Re: runinonmt] #1223241
05/01/12 09:55 PM
05/01/12 09:55 PM
Its a TRAP!
Its a TRAP!
I can't find that article... would you have a link?
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223242
05/02/12 12:32 PM
05/02/12 12:32 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
another thing to think about. per unit length and gage of tubing, dual 2.5" will have 67% more material than single 3" while giving only 39% more cross sectional area. due to boundary layer effects with the greater surface area of the dual pipes, you won't see all 38% flow improvement, probably closer to 30%. so you'll be adding a fair amount of additional weight for not as much flow improvement.
2017 Grand Cherokee Overland
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223243
05/02/12 12:44 PM
05/02/12 12:44 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Could you fit a 3.5" pipe in there? Your surface area of a 3.5" pipe is 9.621", while, as previously mentioned, the dual 2.5" is 9.817", so basically a wash as as far as that goes, but you have the advantages of a single pipe (less boundry layer, weight, etc). 3.5" pipe is a little tougher to find but not impossible.
Re: Dual 2.5" vs Single 3" exhaust [Re: patrick] #1223244
05/02/12 06:00 PM
05/02/12 06:00 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
The single exhaust needs to be looked at harder, but its not something that would sell well, so the magazines wont talk about it
Our 99 Dakota has a single exhaust, and it sounds like a dual x-pipe in the upper RPM range. Our local exhaust guy built it and told us 5 or 6 years ago the x-pipe thing was just a glorified single exhaust.
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223245
05/02/12 08:19 PM
05/02/12 08:19 PM
runinonmt Offline
runinonmt  Offline
Yeah, I couldn't find one either. I finally found the mag."flows as well as a 2.5 inch system and looks stock..sorta'" See attatched. Mopar Muscle Sept '04
Ron
Re: Dual 2.5" vs Single 3" exhaust [Re: runinonmt] #1223246
05/02/12 08:24 PM
05/02/12 08:24 PM
runinonmt Offline
runinonmt  Offline
#2
Re: Dual 2.5" vs Single 3" exhaust [Re: runinonmt] #1223247
05/02/12 08:26 PM
05/02/12 08:26 PM
runinonmt Offline
runinonmt  Offline
#3
Re: Dual 2.5" vs Single 3" exhaust [Re: runinonmt] #1223248
05/02/12 08:27 PM
05/02/12 08:27 PM
runinonmt Offline
runinonmt  Offline
#4
Re: Dual 2.5" vs Single 3" exhaust [Re: runinonmt] #1223249
05/02/12 08:29 PM
05/02/12 08:29 PM
runinonmt Offline
runinonmt  Offline
#5
Re: Dual 2.5" vs Single 3" exhaust [Re: runinonmt] #1223250
05/02/12 08:31 PM
05/02/12 08:31 PM
runinonmt Offline
runinonmt  Offline
#6
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223251
05/02/12 08:44 PM
05/02/12 08:44 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Simple fix... Why don't you run open headers through the hood?
Re: Dual 2.5" vs Single 3" exhaust [Re: runinonmt] #1223252
05/02/12 10:11 PM
05/02/12 10:11 PM
Its a TRAP!
Its a TRAP!
runinonmt, many many thanks my friend!
I'm going to a semi supply store to buy a 3.5" elbow.. IF that fits over the axle, I'm good to go.
Also I agree that the single exhaust for performance apps has to be looked into more.
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223253
05/03/12 07:43 AM
05/03/12 07:43 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
single exhaust can sound good!
http://youtu.be/u4YXAdjfO6o
**Photobucket sucks**
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223254
05/03/12 08:58 AM
05/03/12 08:58 AM
runinonmt Offline
runinonmt  Offline
Glad I could help. Nice to get some use from the old mags. I had a single cat-back Flowmaster on the R/T Dakota I used to have. Worked and sounded good.
Ron
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223255
05/03/12 10:59 AM
05/03/12 10:59 AM
Its a TRAP!
Its a TRAP!
Yeah a single exhaust can sound every bit as good as a dual imo. I was talking with a guy last night who owns a 1986 Iroc (350cid). He was telling me that originally he had dual 2" exhaust w/ cherry bomb mufflers on it for a few years. He then went a built a single 3.5" for it ( 3.5 y-pipe, 3.5 main pipe, flowmaster 40 series muffler 3.5 in/out) and told me that the car went 6/10ths faster in the quarter mile (from 13.60 to 13.00)! I had no idea a dual 2" with cherry bombs were THAT restrictive!
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223256
05/03/12 01:13 PM
05/03/12 01:13 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I patterned the system on my 5th avenue similar to the stealth bomber. I used "cheapie" summit 1 5/8" headers, to 3" 409 stainless collectors, then mandrel bent 409 stainless to a stainless magnaflow dual 3" in/3" out Y, a 3" stainless flex coupler to a dynomax 16669 3"in/out/internal "large body hemi" turbo muffler (10x5x22" case), 3" 409 mandrel bent over the axle, a 3" glass pack in the tailpipe (really helped with interior resonance/drone) to a gibson 3" turn down tip. sounded very nice...here's a clip I put on youtube before I sold it
http://www.youtube.com/watch?v=QvZ2lqPzogQ
Re: Dual 2.5" vs Single 3" exhaust [Re: patrick] #1223257
05/03/12 10:12 PM
05/03/12 10:12 PM
Its a TRAP!
Its a TRAP!
Awesome soound there buddy
My 3.5" elbow is on backorder, time to figure out the rest
Re: Dual 2.5" vs Single 3" exhaust [Re: DARTH V8Я] #1223258
05/03/12 10:18 PM
05/03/12 10:18 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Pssst....you know, if you want to run AN fittings on your heater hoses, you can pull out the factory stainless bungs (they are only pressed in) and tap the holes out to NPT. (they are 2 different sized holes)
Page 2 of 3 1 2 3
