Page 2 of 3 1 2 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215183
04/13/12 04:26 PM
04/13/12 04:26 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Cowl patched with part cut from donor car.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215184
04/13/12 04:29 PM
04/13/12 04:29 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Patched cowl from another angle.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215185
04/13/12 04:34 PM
04/13/12 04:34 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Donor 2d HT Fury and 2d sedan Savoy side by side.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215186
04/13/12 04:39 PM
04/13/12 04:39 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Bumper brackets moved from the donor car.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215187
04/13/12 05:19 PM
04/13/12 05:19 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Even though the extra piece of metal in the previous picture (and the lack of edge) is hardly visible after upper control arms are in place, corrections were made.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215188
04/13/12 05:27 PM
04/13/12 05:27 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Engine room starts to look like it should.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215189
04/13/12 05:32 PM
04/13/12 05:32 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Another angle. Notice the missing part of passenger side inner fender where the hood hinge should be bolted.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215190
04/13/12 05:34 PM
04/13/12 05:34 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215191
04/13/12 05:59 PM
04/13/12 05:59 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Torsion bar rear mounts had been removed to save weight, I guess. They were not needed in a straight axle setup, but now they need to be welded back.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215192
04/13/12 06:02 PM
04/13/12 06:02 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Driver side mount removed from the donor car and welded in place.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215193
04/13/12 06:05 PM
04/13/12 06:05 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Same operation for the passenger side.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215194
04/13/12 06:09 PM
04/13/12 06:09 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Transmission/torsion bar crossmember ready to rock and roll. Notice the crude torched opening for the manual hump.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215195
04/13/12 06:26 PM
04/13/12 06:26 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Next was the trunk floor. It's hard to see from this pic, but there was few dozen extra holes, and a missing spare wheel bracket. No serious rust anywhere. You can also see the modifications made for outer wheel wells for the flares.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215196
04/13/12 06:27 PM
04/13/12 06:27 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Trunk floor ready.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215197
04/13/12 06:35 PM
04/13/12 06:35 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Antenna hole on rear fender welded shut. No radio in this car.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215198
04/13/12 06:39 PM
04/13/12 06:39 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Manual hump had been mutilated with a hole on the side for adjusting shifter rods and enlarged top opening for what ever reason.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215199
04/13/12 06:41 PM
04/13/12 06:41 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
And the hump after Oskari did some corrective actions.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215200
04/13/12 06:46 PM
04/13/12 06:46 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Next part will be the rear wheel openings and outer wheel well. The flares will be gone forever, nothing to save, mostly thick layers of bondo. Here is a small cut to see what it's made of.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215201
04/13/12 06:50 PM
04/13/12 06:50 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
And this is where we are now. I hope I didn't do a major screw-up assuming that 1964 Dodge will have identical wheel openings as a 1963 Plymouth. I know the rear fender is more different the further back you go, but hopefully I can use these. If not, they did a long journey from California to Finland for nothing...
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Another 1963 Max Wedge Savoy project [Re: Anselmi] #1215202
04/14/12 01:53 AM
04/14/12 01:53 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Your metal man is doing a fantastic job. The trans hump looks factory fresh!
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Page 2 of 3 1 2 3
