It ain't a Rembrandt............ #1214891
04/12/12 04:30 PM
04/12/12 04:30 PM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
But I think it'll do.
I wanted to incorporate a thermostat housing into this , so mission accomplished.
Took a 3 X 5 X .375" shear drop for the top......milled it square and cut a .125 lip into it to make it easier to weld the sides , which are .125 " , to it. drilled and tapped the top for the thermostat housing and plunged a 1.5 " hole in it.
Drilled six .750" holes in one side for the AN fittings and bent a 90 degree in the two side pieces to eliminate two seams.
Cut a piece for the bottom , then welded , pressure tested , welded , pressure tested and finally welded and pressure tested it.
A good friend has a TIG and limited experience welding aluminum , so we had a few pin hole leaks that needed plugging.
But after three tries and much cussing , we got it to hold air. I looked high and low for something commercially available for this. No dice.
So until something better comes along , I kind of like this one.
Re: It ain't a Rembrandt............ [Re: tubtar] #1214892
04/12/12 05:25 PM
04/12/12 05:25 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
as long as it works...
Re: It ain't a Rembrandt............ [Re: smokinwoody] #1214893
04/12/12 05:52 PM
04/12/12 05:52 PM
west coast
P
produster Offline
produster  Offline
P
west coast
Rembraint, no. But a pretty cool set up Pableo Picasio...
Re: It ain't a Rembrandt............ [Re: smokinwoody] #1214894
04/12/12 05:58 PM
04/12/12 05:58 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
and goes fast..
Re: It ain't a Rembrandt............ [Re: tubtar] #1214895
04/12/12 06:14 PM
04/12/12 06:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What head is that... W-8... I did something similar
on my W-9
Re: It ain't a Rembrandt............ [Re: MR_P_BODY] #1214896
04/12/12 06:27 PM
04/12/12 06:27 PM
Finland
mafo Offline
mafo  Offline
Finland
I have used earls pro lite hose lately, if you are used to stainless braided you have to try it, you will love it
no comments on design and welding
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: It ain't a Rembrandt............ [Re: mafo] #1214897
04/12/12 06:32 PM
04/12/12 06:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I have started using the pro lite.. yeah that
was pretty sloppy but I had to go back and burn it in...
since then I ground it down and re-did it and polished it
Re: It ain't a Rembrandt............ [Re: MR_P_BODY] #1214898
04/12/12 07:17 PM
04/12/12 07:17 PM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
on my W-9
It's the smaller cammed and carb'ed little Brother to yours Mike.
405 inch W-9.
Ken.......I looked at doing a spider kind of deal , but that would still require a separate box for the stat.
And I had all these lines and fittings laying around.
It'll do until I get tired of looking at it and dream something else up.
Re: It ain't a Rembrandt............ [Re: tubtar] #1214899
04/12/12 08:49 PM
04/12/12 08:49 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
A THING OF BEAUTY IS A JOY FOREVER(or at least till sumthing better comes along)
Re: It ain't a Rembrandt............ [Re: bonefish] #1214900
04/12/12 11:31 PM
04/12/12 11:31 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Just need to polish that octopussie
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
