How to install Hood Scoops on 1971 Duster #1214822
04/12/12 02:22 PM
04/12/12 02:22 PM
United States
K
Katy86 Offline OP
Katy86  Offline OP
K
United States
I am trying to install hoop scoops on a 1971 Duster. I am having difficulty finding instructions on how to exactly install hood scoops for this car. Does anyone know how or can direct me to a website which will explain to me ?
Re: How to install Hood Scoops on 1971 Duster [Re: Katy86] #1214823
04/12/12 02:26 PM
04/12/12 02:26 PM
Wichita Kansas
6PacCuda Offline
6PacCuda  Offline
Wichita Kansas
I just did this on a demon and I used the cut outs in the underside of the hood for a guide. Drilled in the center of the cut outs one at a time and kept setting the scoop on the hood to make sure we were drilling in the right place.
Re: How to install Hood Scoops on 1971 Duster [Re: Katy86] #1214824
04/12/12 03:57 PM
04/12/12 03:57 PM
Eau Claire, WI
Charger727 Offline
Charger727  Offline
Eau Claire, WI
As far as I know Dusters never had functional scoops like the Darts did, but 71 & newer hoods should have cut-outs in the underhood webbing see pic below. The red circled holes should already be there. You'll have to drill/cut the rest as well as the big holes if you want function, good luck
Re: How to install Hood Scoops on 1971 Duster [Re: Charger727] #1214825
04/12/12 10:00 PM
04/12/12 10:00 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
This is how I did my '70 Duster...many moons ago.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: How to install Hood Scoops on 1971 Duster [Re: DynoDave] #1214826
04/12/12 10:51 PM
04/12/12 10:51 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
A little trivia for you. Did you know that no original 1970 & 1971 340 Dusters came from the factory with hood scoops? They were optional on 340 Darts did, 340 Demons, and Duster Twisters (Slant 6 and 318 engines only) but no 340 equipped 70-71 Dusters.
Re: How to install Hood Scoops on 1971 Duster [Re: ScottSmith_Harms] #1214827
04/13/12 06:17 AM
04/13/12 06:17 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I did exactly that on my 70 Dart...Slant 6. The only difference on my installation was the location of the 3 1/2" holes for the forced induction. I moved the holes to the rear of the scoop because I had the notion that air trapped at the rear of the scoop was a bad idea when driving at higher speeds. I had installed HVAC adapters to the hood and slinky aluminum tubing to deliver the cold air to the air cleaner. Also made an opening at the lowest of the slinky pipe with a drain hose leading to the subframe. When you drive in the rain the water accumulates in the slinky pipe and gets redirected under the car...You don't wanna suck water into your air cleaner.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
